2010 Vonats Racer Build( New Chassis color (s)
Has thanked: 235 times
Been thanked: 333 times
Re: 2010 Vonats Racer Build( New Machine work Page 3)
Well today I decided that it was time to hit the track for a little shakedown run, but I have spent a
bunch of time stripping the chassis, milling ect. that it seemed like I was going to have a ton to go through again once I got it dialed in ( at least as far as aluminum re-prep ) So I decided to take the suspension off this car and build a "technicolor vomit" ((tm Temple of speed)) test car :P
I ran about 6 packs through it on a 100 deg day ( our test track is at our house ) and the only real thing I had to do was add some pre-load in the front shocks as the car always wanted to jump very nose heavy, after that a little tuning as a driver to eliminate the on power tight situation I was passing my track mate on the outside(tabletop w/off-camber downhill right & SC10 :lol: ) but the car was super responsive and very easy to move around the track, taking as many different lines and or approaches as I could come up with :roll: . I do need to add a front "bumper" for those nose in's though, maybe not scrub as much then 8)
Oh, also I put the machined stock rear hubs through a pretty rough time as I got re-aquainted with a 2wd buggy 8) ( these things tumble like winged sprints when you time something wrong :shock: ) but I was not sure I had tested them properly--so I handed the car over to my 5 year old and let him run a few packs :P No breakage :mrgreen:
m_vice
Re: 2010 Vonats Racer Build( New Chassis color (s)
Post by m_vice »
Very cool Reg, got a bumper for you I need to send your way, I get back tomorrow. :D
Well, I am going to see this car through even though I am helping Jay move so I can go to the nats :| as a homage' to Jeff's cars
So while I had the chance I machined the rear hubs
I machined the inside of the hubs with a 3/8" flat end mill to get the bearing depth correct, then a 5/8" 4 flute 45 deg bit to finish the cut for the flange of the cvd/cva to clear, then redrill the hinge pin hole to 1/8", then ream with a .002 oversize ream.
Here is where I am at so far, all the suspension and set-ups were tested using the other chassis and parts minus the suspension, the Racers edge hubs are mounted and spaced and she will be raced against B4's and RB5's next wed-
I'll have a donor RCPS Turbo Mirage on it for that race- :|
I also am going with the theme of the Mod Truck entry- http://www.rc10talk.com/viewtopic.php?f=36&t=17617
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
I hope ya kick some arse, I would put some different tires on it though :lol:
Every Canadian is a comedian huh? Who are you really? Mike Meyers?
Slicked off tires at that track are worth almost 2 laps :shock: I am trying a few compounds, we'll see
vintage AE
it's actually my birthday today, so I thought I would see if I could act my age if I added the two numbers together :mrgreen:
I cant tell anyone who I am, just know that my last name is Bond. I told you way too much already, if you experience anything fishy between now and Wednesday, it wasn't me :wink:
vintage AE
I tell the people closest to me that I'm in CSIS, in hopes that some reverse psychology does tricks with them. Some of them question my occupation :lol:
vintage AE wrote:I tell the people closest to me that I'm in CSIS, in hopes that some reverse psychology does tricks with them. Some of them question my occupation :lol:
CSIS? Does that stand for Canadians Secretly Intermarring Siblings?
Or?
vintage AE
Lmfao funny :lol: for quick reference Canadian equivalent to the CIA, but I'm way too mart for them
m_vice
Post by m_vice »
:lol: :lol: :lol:
JK Racing
Has thanked: 129 times
Been thanked: 242 times
Post by JK Racing »
Reg....I'm working on a goldie into racer, getting very close to the part where I would need to do the rear hub carrier "trick"...but I'm too cheap to use the Racers Edge hubs...Do you think I could get away with (gasp!!) using Losi XXXCR rear plastic hubs for this mod?
Yup, give me your addy and I'll send you a set that I have already milled--
vintage AE
lol Reg, I'm in the same situation, do you got another set?
My plan is to mill out a set of B44 rear hubs and use rear B44 CVAs with my RPM Tean Car arms and stealth trans.
I do, just PM me your addy-but they are the B4 ones
Users browsing this forum: No User AvatarGoogle [Bot] and 15 guests
