RC10 Factory Works MIP 93' Worlds Racer Restoration
prp
Been thanked: 13 times
Re: RC10 MIP 4-10 Legend Build
Post by prp »
I confirmed that this car run at the 93 WC in UK... like Rossetti run a 4x4 PRO SE LOSI.
Vintagemishal
Post by Vintagemishal »
prp wrote:I confirmed that this car run at the 93 WC in UK... like Rossetti run a 4x4 PRO SE LOSI.
I had blown up the pictures and could see that it was definitely the same car. Very cool indeed!
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
Vintagemishal wrote:Front gear box is apart for inspection and cleaning. Everything looks great!
what is the size of the C-clips in the front gear box ??
justinspeed79
Post by justinspeed79 »
Holy bombshell batman! :shock:
Too cool! 8)
Vintagemishal
I will try to get a measurement. I am not sure?
Vintagemishal
Phin wrote:
Vintagemishal wrote:...
Good to know. Thanks for the information. I can at least use it to keep the belt in place until I can find an original. I was hoping that MIP could help me out with an original, but does not seem to be the case.
Feel like counting the teeth and measuring the length of the belt? :)
I have not had time to count or measure the belt yet.
Vintagemishal
I have a small update, but a good one. I blew up the pictures that PRP sent from the magazine and I was trying to figure out what motor plate it had on it. I started looking through my stuff, and there it was, it was on the RC10 DS that I got in the lot! Sure enough, it is the same motor plate, cut to fit the back and everything! Then the article says that he was running a Losi Hydra-drive. Again, looking through the stuff, and here is the Losi Hydra-drive on a RC10 B2 gearbox. Promptly took them apart and on the MIP they went. Also put on some Tecnacraft titanium turn buckles in the rear along with some MIP CVD's.
Vintagemishal
Also found this in tote of stuff I got.
JPAE07
Post by JPAE07 »
Wow I have a new respect for the papercliprear end. Awesome find.
I wonder if Eustace is reconsidering the re-re 4wd kit based on the success of the reissue and the fact his poll to reissue the parts was in favor of it.
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
I remember driving by those offices on ol' route 66.
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Post by littleVETTE »
would you happen to have the gear cover? i was looking at the photo that pierre provided and it seems to look identical to a few other associated factory rigs that had the same gear cover at the 93 worlds. i think it was an associated prototype gear cover that had the looks of the original gear cover, but extended for the the hydra drive. i would like to see its features if you have it.
also i'm not a losi guy, but that hydra drive you put on looks to be a little different than most production units. i'm aware some people had different methods to hold the cases together, but that setup you have i don't think i've seen before. it also looks like they milled away material from the outside diameter. maybe to fit the gear cover, reduce weight, etc.? maybe a losi guy could chime in and recognize it.
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
The squared off backs of the lugs used to keep the hydradrive case together are different then my production ones, I bet that's a early / pre-production hydradrive to boot. The lugs on mine are round.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
littleVETTE
kinwald's and masami's looked like normal hydra units. it's kinda hard to see masami's hydra unit, but the glimmer of the metal lug between the spur and case shows that his was a normal hydra unit too.
littleVETTE
looking at it a little more, and i'm starting to think because of the smaller spur gear it was probably done for the sake of the pinion gear. clearance issues.
prp
Post by prp »
Maybe the gear cover is made with 2 RC10 Gear cover cut and glue on each other...
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarYandex [Bot] and 3 guests
