Losi XX and a donor Kinwald
Re: Losi XX and a donor Kinwald
Just to throw in a little more info on the 'C' rating. The 'C' is capacity, so if it's a 5000mAh battery, that is 1'C'. 5000mA=5amps. If you can discharge at 20C, that is 100amps. If you can discharge at 60C, that is 300amps. These are instantaneous numbers, and are a measure of the cell and pack construction's internal resistance. So a higher discharge 'C' means more available current to the motor at rated voltage, which should give you more instantaneous power. Most car's will only hit this area for very very brief periods of time, and you probably won't see a difference between 20C and 60C, these numbers only become more apparent as you run hotter motors.
you can think of it as equivalent to the old brushed motor esc FET resistance, where the 'pro' controllers had ridiculously low on-resistance.
I most certainly will be! Come and find me - be good to meet. I have the yellow body shell today.DerbyDan wrote:Good work mwg..... will you be running tonight? I'm booked inmwg wrote:I've fitted the LiPo battery and the (friends) brushless 6.5T. I will look to get a more progressive engine/esc soon because I anticipate struggling with this combo. The Losi Xcelerin looks like a good buy.
I have also switched the Kinwald chassis (to save my original plastic XX from any big damage).
I have have a new pair of Yellow Mini Spikes (and medium) foam at the rear!
I will need to find a 18T or 19T pinon to reach the recommended gearing (I have a 84T or 88T spur) of 10.3.
I'll wire it in tomorrow at work and drop a few more photos!
I'm looking for you to uphold the XX honor!
Thanks - that's interesting.jwscab wrote:Just to throw in a little more info on the 'C' rating. The 'C' is capacity, so if it's a 5000mAh battery, that is 1'C'. 5000mA=5amps. If you can discharge at 20C, that is 100amps. If you can discharge at 60C, that is 300amps. These are instantaneous numbers, and are a measure of the cell and pack construction's internal resistance. So a higher discharge 'C' means more available current to the motor at rated voltage, which should give you more instantaneous power. Most car's will only hit this area for very very brief periods of time, and you probably won't see a difference between 20C and 60C, these numbers only become more apparent as you run hotter motors.
Thanks for all your help last night Dan! You looked like you were unlucky in the final.
Lots of work still to do on my part!
- DerbyDan
- Been thanked: 19 times
Yeah I was a little unlucky with that back-markermwg wrote:Thanks for all your help last night Dan! You looked like you were unlucky in the final.
Was watching you drive in your final - despite the obvious problem of having an over-tight slipper, combined with mental 6.5 BL power... you have obviously still got the skills from you raced before... it really is a very tough surface to run on yet you demonstrated a high level of skill in-between trying to tame the wheelies!
Haha! You are too kind.
I'll continue to work on the XX and be back!
- DerbyDan
I'm afraid it doesn't, however I have an RPM one on my XXX so i'll try & see if it could be adapted to fit the XX motor plate (the RPM covers don't 'lip' over around the plate so would be easier to adapt)mwg wrote:Dan, do you know if a gear cover from an XXX will fit the XX?
No worries - thanks! The XX RPM covers are hard to come by.
Do you think a 8.5T motor would still be too hot?
- DerbyDan
I know... I got one with that spares car that I recently got hold of, but the previous owner has cut the bottom out of it... so its not very good for keeping the dirt out
Reproductions of the standard lexan ones are avalaible from TBG (team blue groove) in Canada - i've not tried one, but its an option I guess?
An 8.5 would be what I would get if/when I replace the motor I have now.... its probably 'hotter' than would be ideal at your level at the moment... but it would serve you well as you'd probably never have to buy another for sometime, with a 10.5 you may find that in a year or so time as your driving/results improve, that you want to up the pace, so you would need a new motor. Unless of course you have a timing advance/boost function on your speedo/ESC?
I've gone for a 10.5T!
I'm going to try some staggers at the front. Are you using the standard front wheel width?
- DerbyDan
Nice one!mwg wrote:I've gone for a 10.5T!
You should find the staggers give a bit more steering - but more importantly they should make the car less prone to flipping over if you land a little askew off a jump
IIRC the spacing of the ribs on the original XX wheels - to the wheel edge is quite tight to get the tyre lip into - which might make it tricky for you for glueing the staggers on as they do have quite an odd side-wall design.
I've had 8.5 in my CR which will go into the one i'm almost finished doing now, it's got plenty of go in it for me.
I went with the cut staggers on mine, most of the guys at club use minipins all round but i find them far to aggressive on the front so i thought the cut staggers would suffice, and i was really pleased with them.
So I made a return to Silverstone last night with my upgrades! For last night, I had:
* 10.5T motor.
* Front staggers.
* Lowered front and rear suspension.
* Significant weight over the front axle (wheel weights).
The end result was a car that is actually drivable! I won the first heat (D)... had a DNS in the second but ultimately can third in the final but second 1/10th. I did break the rear underside chassis plate however.
Now I must practice to find more time!
* 10.5T motor.
* Front staggers.
- 1689 Views
Last post by LosiXXkid
- 3793 Views
Last post by geeforce59
- 1481 Views
Last post by treehugger
- 4403 Views
Last post by keyesgood
- 2851 Views
Last post by mikea96
- 2118 Views
Last post by rctenracer
- 44 Replies
- 10563 Views
- 77 Replies
- 15859 Views
Last post by mikesofunny
