Kyosho Optima Mid - SWB/Carbon/Runner
- losiXXXman
- Been thanked: 5 times
Re: Kyosho Optima Mid - SWB/Carbon/Runner
I missed the latest update on this. It's going great, I like all the white on the car. RPM makes some of the style rod ends on the rear, they're badged as traxxas ends, and they come in white. Here's a link but you can probably get them anywhere..
http://www.ebay.com/itm/NEW-RPM-Rod-Ends-Short-White-1-10-Traxxas-80471-NIB-/290696780246?pt=Radio_Control_Parts_Accessories&hash=item43aee0d9d6#ht_667wt_2362
Which size pivot balls do you need to work with those, and what size screw do you need to use with them
I have a need for something similar on the front of one of my Lazer/Mid hybrids and bought some metal rod ends instead but this could be a neater solution
- losiXXXman
Per tower's website (IDK how reliable
) Those are to replace stock traxxas rod ends which use these 4.5 mm balls. Like these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXSD0&P=7 They need a 2.5mm screw, I think?
- j0pp3
- Been thanked: 4 times
Thanks for the tip guys! I left this project alone for awhile to work on my LWB shelf queens. I tend to change focus now and then
Just got the info that our yearly vintage meeting will be held in may/june this year so I have time to make it a great runner. Before now I was certain that the car should get a brushless motor and lipos but after I went through my pile of vintage electrics I might use some old stuff.
Cheers
Joel
Joel
- flipwils11
- Been thanked: 19 times
I'm not a Kyosho guy but this is a great project! Super looking end result.
- Been thanked: 325 times
j0pp3, all your builds are excellent; the threads are even more excellent than the builds, haha! But this one, I like the little details that you're focusing on; the white ball-cups & nuts to match the arms and body. That (in addition to the carbon fiber) sets this car apart from the rest. I hope you can find white captured ball-ends for the rear outers, but I honestly can't recall ever seeing them in white...good luck in your search.j0pp3 wrote:Here is a small update. Replaced the yellow nuts with white ones. Also mounted white rod ends (RPM), black turnbuckles (Axial) and matching ball studs (Associated). In the rear I still have black outer rod ends because of the different mounting. Maybe I could find white versions of those too?
- keithrc
- Has thanked: 20 times
- Been thanked: 15 times
Any updates on the runner Mid JOpp3?
Keith
Keith
NIB Optima!
NIB Turbo Optima
My threads:
Optima's http://www.rc10talk.com/viewtopic.php?f=30&t=29477
Mids http://www.rc10talk.com/viewtopic.php?f=30&t=29489
Lazer's http://www.rc10talk.com/viewtopic.php?f=30&t=29525
NIB Turbo Optima
My threads:
- j0pp3
Thanks guys!
This car has become a long-term project but I have a mini update for you. Found some SG Coyote rear tires on Ebay (at least they were advertised like that) and temporary put them on some random five-spoke touring rims (that is too wide). Together with a yellow colored body this became an alternative look for the car. Emperors new groove?
Cheers
Joel
Joel
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
the rear arms are more than translucent now...
the contrast with the black is awesome!
Paul
Paul
- j0pp3
Uuups, this time I forgot to compensate for the overexposure
Next step involves crafting another rear shock tower so the body can be mounted properly. Also have to find a set of slimmer rims.
Cheers
Joel
Joel
I'll start to make carbon wings.
Have lots of ideas in my head.
Could fit this car perfect.
Jerzi
Jerzi
- j0pp3
That will be interesting to see!Jerzi wrote:I'll start to make carbon wings.
Jerzi
Thanks Dennis! I'm soon going to try using a sheet of "astro turf" as a background instead. Then it might look like she's on the local track alreadyDennisM wrote:Awesome picture - Looks a little loose in the rear though
Cheers
Joel
Joel
Looks great, j0pp3.
The rear tires look a tad narrow, mind you...I wonder how it would affect traction at the back?
- j0pp3
I understand your concern, Coelacanth. Although I don't think it will be a problem as I will run it on astro turf.
Here's a fish-eye photo from last outdoor season showing the track at our local club. Only problem right now is that it's still partly covered with snow...
Cheers
Joel
Joel
- 29 Replies
- 2986 Views
Last post by j0pp3
- 26 Replies
- 3752 Views
Last post by Hcp22
- 1969 Views
Last post by Lonestar
- 3699 Views
Last post by alcyon
- 2305 Views
Last post by Jerzi
- 1534 Views
Last post by Mad Racer
- 3191 Views
Last post by Bo Wallen
- 1938 Views
Users browsing this forum: Mojeek [Bot] and 6 guests
