TCP Runner/Racer
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: TCP Runner/Racer
I have exchanged PMs with CobraKen, he reproduces the stock bodies and has a belly pan too. After the race day, there really wasnt much if any dirt inside. The body hangs down below the chassis which helps.
Have you played with using the "extra" holes in the shock tower to put modern wing mounts? They look about the size of Kyosho/Losi mounts. I will try some out next time I have it at the track/LHS.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I have been looking at the RB5 wing mount and it looks like it 'd fit but If it doesn't, I don't mind making 4 extra ones
At the the moment I'm using yoky wing mounts and the not-so-good old wire method.
- JK Racing
I bent the wing tubes on a large ski jump, so the wing dont fit all that well any more...you have a set of K car mounts to try? Lemme know!
- Mr. ED
err, no, not yetJK Racing wrote:you have a set of K car mounts to try? Lemme know!
- JK Racing
I should have some time to check mounts this weekend (fingers crossed).
- JK Racing
I pulled the whole car down, cleaned it up, replaced almost all the philips head screws with hex head screws, new front bumper (rustler). I put the brushless set up in there, with no timing (waaaaa), so I geared it to the moon. 33/72, but it feels good out in front of the house (doesnt feel as punchy, but similar top end as when I was running the 17.5 boosted on 28/81). Its been raining here, so no track time this past weekend or next weekend. I will attempt to hit an indoor track, but their race times arent as family friendly as the local outdoor track.
I'm going to pick up a spare idler, diff gear and metal top shaft gear. The stock Delrin top shaft gear looks a touch on the worn side, and with brushless/lipo, I'm not worried about the weight gain (it shouldnt be much anyways).
Updates when I can (and I will try solid wing mounts soon also, LOL).
- Mr. ED
I got the ZX5/RB5 wing mounts. They are 1mm off from the spacing between the existing holes, but I would mount it a little higher anyway.
I think you can easily get away with only 1 pair of extra holes.
- 1822 Views
Last post by badattitude
- 90 Replies
- 10510 Views
- 32 Replies
- 4063 Views
Last post by fordtransman
- 953 Views
Last post by mikea96
- 2028 Views
Last post by Minicooper 35
- 1739 Views
Last post by Mad Racer
- 93 Replies
- 18543 Views
- 715 Views
Last post by blown5.0
