JRX2 5-link racer build
- RCveteran
- Has thanked: 26 times
- Been thanked: 200 times
Re: JRX2 5-link racer build
Yes it originally came out of a T4.1 I had. It has bashing sessions on it and a lot of racing use and no issues. The ESC has some throttle profile adjustments and all the usual adjustments and I find it easy to navigate through the programming.
If you pay attention on the BAY you can get the combo for $75, for a name brand ESC and motor I think its a good deal. If only it said Losi on it.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
A well placed sticker can fix that...Losi does sell brushless systems, Xcelrion (probably spelled wrong), I have had a few of the motors, my son uses a 17.5 Losi motor in his T4!RCveteran wrote:If only it said Losi on it.
- RCveteran
Teaching him young about getting along well with oppositesJK Racing wrote:, my son uses a 17.5 Losi motor in his T4!RCveteran wrote:If only it said Losi on it.
RCveteran wrote:It's definitly nose up and the rear seems to smack easy so say on the small double unless I hit just right it seemed the rear woudl smack off the jump and actually send the car tumbling, on the bigger more launch friendly jumps definitly nose up.
As a side, I installed the kit for a XX A-3111 dual disc slipper, fit right onto my single slipper shaft so now spurs are a piece of cake.
This is nice (XX A-3111 dual disc slipper) , this is exactly what i need for my pro,is this still available?does the assebmbly includes the top shaft?
Any links will be appreciated.
Thanks,
Jun.
― Confucius
― Confucius
- bgruen
Glad to see another 5 link runner. Watch for rear shock ends and buy them of you come across new ones. The original shocks would leak and if a car was stored for years the oil would leak out onto the shock end and rot them.
You should replace the steering rack with the aluminum bellcranks you got with the other non-losi parts. To do this you will need to drill a third hole on the left that is symmetrical to the one on the right. It will work just as good and won't fail like the rack bar is prone to.
Bob
Bob
Writer, producer, and director of The Hobby Stop:
Available on:
Available on:
- Amazon
- iTunes
- Google Play
- YouTube Movies
- Microsoft Store / X-Box
- Regular Member
Could you tell me what axles you used and maybe the part numbers, I see you are using the custom works spacers? What size links are you using to do the turnbuckles and the links on the suspension? i also am building a racer X2 but its the original not the Pro.
Thanks
Thanks
- Been thanked: 4 times
You mentioned that you used the XX A-3111 dual disc slipper. What input shaft are you using with it? The stock one is way too short. I'd like to get my JRX-2 converted over to a slipper system so anything you can tell me would be helpful.
What rpm parts did you use for the rear 5 link setup? I have the H-arms but would really like to go back to the old system if possible. It is extremely difficult to find any 5 link parts anymore so I have no idea how I'm going to accomplish it without buying a complete car somewhere as that's the only place I ever see them. As long as it's going to be a challenge to find the parts anyways, I may as well search for the rpm parts.
- JK Racing
Fred, the Pro SE & LXT had the slipper shaft you need. Assuming you are using the LRM tranny, search for the stock Losi slipper shaft and you are good to go. You can use the slipper parts from the current (former) XXX buggy also.
fredswain,
you can use a hrdyra drive shaft (forgot the part number) and use a B4 back plate similar to the one below.
― Confucius
― Confucius
Cool. Thanks for the help. Now I know what to look for. Any ideas on where to find 5 link parts, especially the rear hubs??? If I had those pieces I could build the rest.
- Been thanked: 12 times
ebay and the buy-sell-trade section here are the only real sources. 5-link parts come up all the time you just have to be patient.
I have had good luck building a parts stash for runners by buying complete cars that have a bunch of spares with them.
If you are going to run once it is built, might as well buy a cheap spare care for parts, will save a lot of $ over buying individual NIP parts.
Some just showed up buy it now so now I've got them. I bought a JRX-pro parts car for $30 last week as it was cheaper to get it for the parts that I needed rather than look for them individually. It has the H arms though. The car currently has the RPM rear arms on it but I don't like them. At least I'll be able to compare both original systems now.
- 26 Replies
- 4416 Views
Last post by RCveteran
- 1152 Views
Last post by FasterLouder
- 23 Replies
- 4690 Views
Last post by Garage Hack
- 21 Replies
- 2569 Views
Last post by UltraHIVE
- 33 Replies
- 3585 Views
Last post by adam lancia
- 1542 Views
Last post by MelvinsArmy
- 1108 Views
- 1357 Views
Last post by DHC6
