Building 5 link vintage racer - which chassis?
- RCveteran
- Has thanked: 26 times
- Been thanked: 200 times
I am going to build up a 5 link runner to try out at a vintage event. What's the consensus; should I go with the longer jrx pro chassis with the 30 degree lip or stock Jrx2 chassis? I have some beat up ones of each that will work.
Re: Building 5 link vintage racer - which chassis?
i'd say that kind of depends on the track layout.....short technical course, I'd go with the shorter jrx2 chassis.
long sweeping courses, I'd run the longer pro chassis....
personally i like the original short chassis with the 5 link. the car steers very well with it. the long chassis slows down the steering too much for my liking.
I believe the strengths of the original 5 link were that it was better balanced for choppy and rough tracks, so again, make your decision based on track conditions.
- RCveteran
Sounds good, how do you guys feel about the long shocks and JRX-T shock tower on a buggy, I know this was a popular mod back in the day and I could go either way. The long shocks in front and 5-link certainly give you way more suspension travel than modern buggies and the outdoor tracks around here tend not to be groomed all that well.
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
And that rear end is wicked off the corners toojwscab wrote:I believe the strengths of the original 5 link were that it was better balanced for choppy and rough tracks, so again, make your decision based on track conditions.
I would like to see the original jrx2 using some new shocks like the bk2 or cr. The shocks nowadays are way better handling...in my opinion, I like the losi shocks better then associated.
the old losi shock bodies are still fine. i have mine outfitted with xxx cartidges and they are as smooth as any modern shock. maybe not as smooth as a coated body but pretty darn close.N2Deep wrote:I would like to see the original jrx2 using some new shocks like the bk2 or cr. The shocks nowadays are way better handling...in my opinion, I like the losi shocks better then associated.
have you guys noticed a change in the cartridges? I seem to recall the old ones had an outer o-ring, but some new ones I got from horizon look like they are just tapered to seal. Was I seeing things or is this real? And is that OK for the old bodies?
I would go with the shorter original chassis with the T shock tower and longer shocks. Great handling chassis, properly set up with modern tires is still pretty darn quick!
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
- 31 Replies
- 5081 Views
Last post by peetbee
- 26 Replies
- 4411 Views
Last post by RCveteran
- 74 Replies
- 12214 Views
Last post by dldiaz
- 819 Views
Last post by TitleSeventeen
- 4477 Views
Last post by andymac0035
- 1499 Views
Last post by Welshy40
- 1151 Views
Last post by Mr. ED
- 993 Views
Last post by jcwrks
