The ultimate Mini JRX2 thread
Burniefloyd
Has thanked: 85 times
Been thanked: 92 times
Re: The ultimate Mini JRX2 thread
Post by Burniefloyd »
Mine shipped today. Says it should be here Saturday.
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
Burniefloyd wrote: Thu Mar 02, 2023 4:21 pm Mine shipped today. Says it should be here Saturday.
Just checked my email and saw I had a notice as well.
Next we'll all have to see who got the lowest number. Lol!
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Mine says delivery by 7pm tomorrow - Fed Ex normally shows up by Noon here. But I will be at work until 6 pm...such is life :)
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Mini JRXT just arrived.. #3835
-Brad
HS-YZ250
Post by HS-YZ250 »
Wow! This "pre-order" went quickly!
Losi JRX Pro SE
Kyosho Rocky
RogueIV
Has thanked: 2139 times
Been thanked: 1100 times
Post by RogueIV »
HS-YZ250 wrote: Fri Mar 03, 2023 3:18 pm Wow! This "pre-order" went quickly!
Losi apparently still has some in stock.
BattleTrak
Here’s a look at the different motor plates..
Mini JrxT has holes for 14-16 tooth pinions and comes with a 15t.
Mini Jrx2 has holes for 17-19 tooth pinions and comes with a 17t.
They both use the 60t spur gear. I would like to see Losi release an optional motor plate with slotted motor mount holes like the original.
-Brad
RogueIV
Post by RogueIV »
BattleTrak wrote: Sat Mar 04, 2023 5:21 pm Here’s a look at the different motor plates..
They should have done that from the start and also made it from thicker material. Hopefully the JRXTs don't come with pre stripped motor plates like 2 of my JRX2s did, especially with it being the serialized part...
I might model up a plate and see if I can get some made of thicker material and with slotted motor mounting holes. No one else seems to want to do it.
JK Racing
Post by JK Racing »
Is my mind playing tricks? Wouldnt the larger pinion be further away from the spur, not closer?
RogueIV
Post by RogueIV »
JK Racing wrote: Sat Mar 04, 2023 10:27 pm
It is, you're rotating the entire motor with these holes, the lower side is the opposite direction
HS-YZ250
Post by HS-YZ250 »
Got mine over the weekend: #3402. Already dinged the motor plate. Lol!
I guess the really low numbers went to distributors.
I don't want to burn up the step pins. Are there any mini-T tire options that aren't pre-mounted? Didn't see any at A-main.
Losi JRX Pro SE
Kyosho Rocky
HS-YZ250
Post by HS-YZ250 »
HS-YZ250 wrote: Thu Mar 02, 2023 9:16 am I was wondering if I could piece together a lookalike between JRX2 Mini and Mini-B parts, and 3d printed stuff. There's probably not enough high quality images of the prototypes to count pixels on. And, of course, I never finish my projects. Lol!
Did find a couple of large enough prototype images on this forum and the front end looks almost exactly like a XX. Saw somebody else on here modeling stuff for the mini, so if I ever get free time again, I might take a stab at grafting scaled down XX parts.
Losi JRX Pro SE
Kyosho Rocky
RogueIV
Post by RogueIV »
HS-YZ250 wrote: Mon Mar 06, 2023 9:50 am Got mine over the weekend: #3402. Already dinged the motor plate. Lol!
The JRXT wheels and tires are much bigger than Mini-T which uses the same size as the Mini B. The wheels on the JRXT are 1.5"x1.35" thankfully Losi does sell spares. Not sure who else sells tires for a 1.5" wheel though.
I pulled my serialized motor plate off and put one from a JRX2 on and just drilled the plate so I can run the stock 15t gear since the JRXT plates aren't available yet.
Like the new body clips they used for the body, not sure why 1 wasn't used for the battery box though.
Despite being Limited Editions doesn't mean the assembly team really cares. Still managed to mess up properly assembling the shocks and seem to have employed Hercules himself to tighten these cartridges on.
Basically went through mine yesterday when it arrived and prepped it for the Mini Nats which is fast approaching. nothing too out of the ordinary, same issues with assembly as the Mini JRX2. I do like that they use proper length springs in the back on the truck though, so now you can actually adjust the rear ride height more. Haven't gotten to really run it yet other than just driving it down the hallway a few times.
Also of note, same issue with the JRX2 a small spacer is needed up front to keep the wheels from slightly rubbing on the carriers. Also fair amount of play in pins. Also the outside bearings up front ride on the threaded part of the axles, which in turn has a lot of slop because the threaded part is slightly smaller in OD than the rest of the axle.
HS-YZ250
Post by HS-YZ250 »
RogueIV wrote: Mon Mar 06, 2023 3:00 pm
First look is all crawler tires. https://www.amainhobbies.com/1.5-tires-tires-wheels-rock-crawlers/c9924?fk=37_1739&lg=fk37
Wonder if there's an odd tamiya kit that is close.
*EDIT* Looks lie Mini-B FRONT tires are close. Could always try that old cut-and-glue-to-make-your-own-tires trick from way back in the day!
Losi JRX Pro SE
Kyosho Rocky
RogueIV
Post by RogueIV »
HS-YZ250 wrote: Mon Mar 06, 2023 4:11 pm
It's a shame they didn't go with 1.6" wheels, could have used the JC RC10 tires in that case. You could also probably stretch the JRX2 tires onto the JRXT wheels.
Return to “Losi Forum”
