Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Phin wrote: Sun Jan 28, 2018 9:06 am Maybe there was a 553 rank that used bearings. :lol:
Heh, turns out there were MRP 553 motors. I was just looking through old magazine scans and happened to notice a bunch of them listed in a 1981 race report. :o
AYKBOBCAT
Post by AYKBOBCAT »
Can someone tell me what this MSC was for? Kyosho? What car?
Been thanked: 3919 times
Looks like Fox to me
AYKBOBCAT
Post by AYKBOBCAT »
Ah! you are right! Thanks.
Basher67
Has thanked: 44 times
Been thanked: 160 times
Post by Basher67 »
I've had these laying around for a while and have no idea what they are or what they fit. Looks like 1/8 on road? Possibly early brass sleeve bushed front wheels? Wheel diameter is 2" and tire diameter is 3 1/4". Tires are 1 3/4" wide and the wheels are a hair wider at 1 7/8"
Phin
Post by Phin »
They might press fit on a tapered Kyosho stub axle.
heavy_gear
Post by heavy_gear »
i got this in a lot of 4 cars, google searches havent helped me get any closer,
it sits on some losi road weapon tyres, so my question is: is it a losi ?
i personally think its a clone of some sort, maybe traxxas...
thanks in advance for the info and help
Looks like a losi high roller
Brocklee
Has thanked: 17 times
Been thanked: 23 times
Post by Brocklee »
I got these out drives in a xxt I got in pieces and i haven't seen any with deep grooves in them like these. They look like the groves are machined into them on purpose. Are these aftermarket of some sorts and why is there a deep groove in them?
Xxt outdrive
Xxt outdrive
Cars: kyosho raider, rc10 ce, kyosho ultima pro xl, lazer zx, inferno mp s, losi xxt, xx4we, rc10t3, kyosho zx5 sp, rb6, zx6, rb7ss, zx7, mp10e, crc xl, rc18r, tamiya trf 801xt.
Been thanked: 1319 times
Are they aluminum? Typically happens when you don't use pin cushions with them.
Brocklee
Post by Brocklee »
scr8p wrote: Mon Feb 19, 2018 5:15 pm Are they aluminum? Typically happens when you don't use pin cushions with them.
No they're magnetic, on the side opposite the groove it doesn't have much wear on them and the cvds aren't the worst I've seen either (not sure how much on an indicator that would be though)
Brocklee
Post by Brocklee »
Brocklee wrote: Mon Feb 19, 2018 5:23 pm
I guess if you were to lock the cvds straight using the grooves you might have less drivetrain losses at the universal joint possibly for stock racing?
That is not done on purpose. If it was, it’s unfortunate because it won’t work. Those are basically toast
Brocklee
Post by Brocklee »
GoMachV wrote: Mon Feb 19, 2018 5:36 pm That is not done on purpose. If it was, it’s unfortunate because it won’t work. Those are basically toast
Hahaha I figured as much, I've just never seen any wear down so perfectly before
They were probably used on an oval car or something without much rear suspension travel. So they kept getting hammer at those spots every time the throttle was pulled.
Return to “Identifications”
