RC10 Classic 40th anniversary
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Re: RC10 Classic 40th anniversary
Post by XLR8 »
GreenBar0n wrote: Wed May 15, 2024 12:29 pm Anyone know the name of the condition, or sickness, that compels one to build the wheels first, with every model?
Can't quit doing this. Cart before the horse syndrome?
I'm guessing it makes you a wheelophile? :wink:
Anyway, those look nice. Where did you find them?
BTW, a word of caution when you are fitting the body. Drill the front body post hole last and ignore the center point that is marked -- it's way too far aft. :x
GreenBar0n
Has thanked: 1271 times
Been thanked: 861 times
Post by GreenBar0n »
XLR8 wrote: Wed May 15, 2024 3:13 pm I'm guessing it makes you a wheelophile? :wink:
Wheelophillia :D, or rimplaysia.
Thanks! These are the Dhawk wheels from ebay, got his knock offs too:
https://www.ebay.com/itm/203188929632
And thanks for the warning on the body, that's crazy that it doesn't match the front dimple.
XLR8
Post by XLR8 »
GreenBar0n wrote: Wed May 15, 2024 6:34 pm
Rimplaysia seems correct. :wink:
Those wheels are super deluxe. I need a set. :D
It appears maybe they used a taller body post to mark the hole location. I've replaced the four supplied washers with a bespoke aluminum spacer (0.35" tall) and the body seems to fit a little better. Anyway, I'm ready to order some Camel Yellow and finish it. Meanwhile, it's back to the RC10T for me. :D
GreenBar0n
I'm thinking about painting the boxart stripes on, like Andy does. I'm no where near that skill level, but I have Polycarbonate Cleaner, and can keep trying.
https://www.rc10talk.com/viewtopic.php?t=24555
I hear the long decals that run the length of the body under the windows, are too wide in one spot, and it pulls up from the body, and won't stay stuck. Might try the decals and painted on, I have a spare Protech body, or two here.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
Finally managed to go pick mine up.
Hey Cru ! Go balls out 8)
RogueIV
Has thanked: 2139 times
Been thanked: 1100 times
Post by RogueIV »
IDK but I did the same thing and I'm not even using the wheels right now. They're just so cool looking though!
I also started designing parts before I even built the car, not sure if that's another sickness.
GreenBar0n
Are you guys cutting out the body and then painting it, or painting it first, and then cutting it out? Is there a benefit one way or the other?
I noticed Andy's sells his painted first, or not cut out.
Been thanked: 3919 times
Personally I do both, depends on my mood and trust of cut lines. Tamiya or kyosho bodies no problem. I do not trust AE cut lines or holes. I would get it mounted first then paint. For the body mount holes I like to leave the posts off and get the body fitting properly, then add the rear post by looking straight down and making a mark, install the post and cut the hole. Then on the front use a long screwdriver to project where the body mount will end up, being it's at a 30⁰ angle you might want to make the hole small at first, and progressively make it larger and more oval.
If you do paint first, when cutting it out try to keep the scissors oriented so they are not touching the paint on the "good" side. Hard to explain but once you rub into the paint with the scissors you will see what I'm talking about haha.
GreenBar0n
Thanks for the sound advice. I'll cut it out first, mark and ream the mounts, and then paint it.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Nothing sucks more than painting up a killer body only to drill the holes wrong
Dangeruss
Has thanked: 425 times
Been thanked: 1411 times
Post by Dangeruss »
GreenBar0n wrote: Wed May 15, 2024 6:34 pm Wheelophillia :D, or rimplaysia.
Google Rimplaysia and check out what the first result is... too funny.
XLR8 wrote: Wed May 15, 2024 7:04 pm Those wheels are super deluxe. I need a set. :D
It's like the Sees directionals Horizon Hobby put on the 10T for their Andy's Ad... one day I was fine, then came... I need a set. :lol:
Horizon 10T Sees Wheels.JPG (19.54 KiB) Viewed 725 times
https://www.rc10talk.com/viewtopic.php?t=49366
XLR8
Post by XLR8 »
GoMachV wrote: Thu May 16, 2024 12:14 am ...I do not trust AE cut lines or holes. I would get it mounted first then paint. For the body mount holes I like to leave the posts off and get the body fitting properly, then add the rear post by looking straight down and making a mark, install the post and cut the hole. Then on the front use a long screwdriver to project where the body mount will end up, being it's at a 30⁰ angle you might want to make the hole small at first, and progressively make it larger and more oval....
Now, ya tell me. :roll: :lol:
1911Colt
Has thanked: 1783 times
Been thanked: 860 times
Post by 1911Colt »
Apart from being historically inaccurate, why not use velcro on the sides and avoid drilling any holes in body? The RC10 seems tailor made for this. Or does the body not sit as closely to the sides of the tub as I think it does? (I never owned one; I just had the 10T).
All of my vintage Schuey buggies use velcro. I still screw up the paint lines and the window masks, but I never screw up the body holes :D I do screw up the wing mount holes. :(
GreenBar0n
Dangeruss wrote: Thu May 16, 2024 4:19 am
What am I missing? All I see is @XLR8's post, and the wheel pics I posted, also some Maximum Overdrive happening.
Dangeruss
Post by Dangeruss »
GreenBar0n wrote: Thu May 16, 2024 1:14 pm What am I missing? All I see is @XLR8's post, and the wheel pics I posted, also some Maximum Overdrive happening.
Your post at the top of the page is the first result. Not the first of one million results, but the first result... ever.
You just created history.
Sure, it's not the invention of the wheel... but if someone reads your post, then scrolls down and see's my post directing them to google rimplaysia, whey they do they get your result. When clicked it lands them on your post, and when they scroll down it leads them to my post... it's a time loop! ...like the kind of thing they send T-100's back to stop... Image
