I spy with my little eye. . .
- Erich Reichert
Re: I spy with my little eye. . .
Yes I am going to repro it along with a couple other bodies I've picked up. I have a place to make a mold for me and I'll be posting more info real soon. Thanks guys.
- Dr. Robotnik
I have a quick repro question...Erich Reichert wrote:Yes I am going to repro it along with a couple other bodies I've picked up. I have a place to make a mold for me and I'll be posting more info real soon. Thanks guys.
On a body mold do you have to drill tiny holes in the mold to allow proper forming as you would complex small pieces? Or are they not that detailed?
- Erich Reichert
typically not that detailed... i knowthe body molds i've seen of Protoforms don't have them, those are more to get the pulled piece to release around wierd shapes and such if i'm not mistaken. I don't know for fact though... this place is doing the mold and the forming for me
- Dr. Robotnik
Thanks for the answer.
Can you ask them what plaster they use please? I would like to mold my huge 1/8th Hobby Products body if possible you see.
- Erich Reichert
- Dr. Robotnik
- mikedealer
- Dr. Robotnik
Thanks mate.mikedealer wrote:hydrostone is way to go
Will that release from the shell once I have used it leaving me with the old shell to use if I wish?
P.S. I will do you a HT wing template tonight (if my memory works)
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
Yes, every body needs vents adding to let the air escape. Every groove, such as the window markings, need holes to get the air out of it and any internal radius, such as where the sidepods on an RC10 shell join the body. These holes ideally need to be no bigger than 1mm in diameter, ideally smaller if it can vent properly. Anything bigger than 1mm will show up as a dimple on the surface. You'll find out when you try vacforming a mould, you'll find you have to keep adding holes to get it to pull down properly.Dr. Robotnik wrote: I have a quick repro question...
The difference is Erich is planning on making bodies for sale, which requires a stable pattern that will last for many pulls without breaking down. Even the hardest plaster isn't going to last for dozens of pulls without damage, never mind hundreds. Tooling resin also does not shrink at all when you make a mould with it, unlike most plasters, silicones and resins which have an amount of shrinkage as they harden. This is why some of Kamtecs repro bodies are a bit smaller than the originals, in the case of his optima body it's about 10mm shorter later bodies he uses more appropriate materials. The disadvantage of tooling resins is the price. Having a trade account means I can order it, but here in the UK enough to fill one buggy body would cost me £70/$140Dr. Robotnik wrote:I was advised to use plaster on here. Hmmm. That is odd.
- mikedealer
awesome thanks!
Dr. Robotnik wrote:Thanks mate.mikedealer wrote:hydrostone is way to go
- Dr. Robotnik
Thanks for more forming info guys, I am currently doing some slow online research for it. I have no idea how I'd drill 1mm holes in my 1/8th body mold though, maybe make it hollow.Hmmmmm
Something came up I am afraid and I forgot. I will definately get it done this week.mikedealer wrote:awesome thanks!
I won this the other day http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270211481093
It's actually a Kinwald/CR style shell not the original XX. i was planning on putting it on my RPM moulded car, Anyway, when I went down to see the guy, it figures he had these too: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270211486633
The Turbo Mirage is as new, painted really nicely. Needless to say. I made a very reasonable cash offer for the three shells and now they are sitting on my cars!
- 171 Views
Last post by Frankentruck
- 1788 Views
Last post by sandkil
- 40 Replies
- 6809 Views
Last post by MarkyDents
- 467 Views
Last post by templeofspeed
- 825 Views
Last post by a01butal
- 2979 Views
Last post by XLR8
- 33 Replies
- 3765 Views
Last post by lexus-5
Users browsing this forum: 1911Colt,
DotNetDotCom.org [Bot],
Dustydrone,
Google Adsense [Bot],
R6cowboy and 5 guests
