Tecnacraft Worlds RC10
MelvinsArmy
Been thanked: 11 times
Re: Tecnacraft Worlds RC10
Post by MelvinsArmy »
It's a 5 inch wing.
As far as trying to make your own aerofoil, I think it would be very difficult. I think aconsola's idea is probably right, that this form was made in a longer length, then cut into smaller pieces. Like I said, the two sides are fused together, I've never seen that on anything lexan before. You might be able to bend lexan around and glue or screw it to itself on the other side. It would probably take quite a bit of trial and error, and even then I think it would be very difficult to make the aerofoil shape. I think you'd probably have much better luck if you tried it with a piece of aluminum.
As far as being able to locate a Tecnacraft Aero-Foil. I've waited over six years to find one, and it certainly wasn't for lack of looking. :wink: Good luck to anyone else who might want one.
shodog
Been thanked: 91 times
Post by shodog »
It's possible that this could have been blow molded kinda like they do with plastic water bottles
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
Probably extruded. Aren't the screw holes molded through the whole length of the wing?
asashaw
Post by asashaw »
nice!
MelvinsArmy
templeofspeed wrote:Probably extruded. Aren't the screw holes molded through the whole length of the wing?
The wing is actually in five pieces, minus hardware. There's the aero-foil center, the two sides, and to hold the whole thing together there's two tubes that run through the wing from side to side that the scews tie in to. I'm not sure that they're just two plain old clear antennas, but they are made of a similar material if they're not.
MelvinsArmy
This car is for sale in the bst, minus the Aerofoil and front bumper.
mrlexan
Post by mrlexan »
Looks great Mel, should go quick. Best of luck.
www.gojammedia.com
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
I figured this thread deserved a 15 year bump. :mrgreen:
The TX SKUNK
Users browsing this forum: No User AvatarAhrefs [Bot] and 7 guests
