Cheapo motor testing
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Cheapo motor testing
yes. probably because it isn't a copy but the exact same thing barring the ezrun label.
- Has thanked: 14 times
- Been thanked: 5 times
Well the SkyRC combo's wiring wouldn't work on a 10T. I originally ordered extensions, but those didn't fit. So, I extended the motor wiring and ordered a longer sensor cable. I'll have to add that to the cost of the kit, making it not quite as cheap as I originally hoped.
When I installed the new sensor cable and grabbed the program card and began trying to tune the sensored setup in the truck today and noticed an odd problem. If I quickly applied full throttle on a high grip surface from a dead stop, it would cog badly or some times make a high pitched whine and not move. I'm unsure what that is.
update edit:
The problem steadily got worse and now it barely wants to move. The ESC seems to be fine, I'm thinking the motor has a problem.
update edit:
- Been thanked: 325 times
Slap in a different motor. The ESC is already calibrated so it shouldn't take anything more than a motor swap to see if that was the culprit.
- i crash cars
Was this with the Hobbywing clone or the SkyRC system?Jimbo302 wrote:When I installed the new sensor cable and grabbed the program card and began trying to tune the sensored setup in the truck today and noticed an odd problem. If I quickly applied full throttle on a high grip surface from a dead stop, it would cog badly or some times make a high pitched whine and not move. I'm unsure what that is.
update edit:
That was the SkyRC sensored motor that died on me. It had never even been outside the house yet. I really haven't fiddled with any of it since, actually.i crash cars wrote:Was this with the Hobbywing clone or the SkyRC system?Jimbo302 wrote:When I installed the new sensor cable and grabbed the program card and began trying to tune the sensored setup in the truck today and noticed an odd problem. If I quickly applied full throttle on a high grip surface from a dead stop, it would cog badly or some times make a high pitched whine and not move. I'm unsure what that is.
update edit:
Agreed. I'm going to try a Leopard 2180kv 16.5T motor that I got for just under $25. I had really good luck with their 9T version of the same motor.Coelacanth wrote:Slap in a different motor. The ESC is already calibrated so it shouldn't take anything more than a motor swap to see if that was the culprit.
- yellowdatsun
I run a 3100kv model of the blue one you have installed.
So far, so good. Ill try to post back any issues.
The motor will stand my 10T on the back bumper easily.
I also noticed that it ran very cool, except for when I was making it push around the 10T even though it was running on the nose plate.
KO
KO
Over the weekend I completely submerged the 10T in water with this motor and ESC.
It still worked but would accelerate on it's own, I put the ESC in a bag of rice.
The next day, pulled it out, reinstalled it and it works as well as always.
Still very happy with the combo.
KO
KO
Is this the difference between a tuner and a ricer?
[/quote]
[/quote]
I did have to pick the rice out of the esc fins LOL
KO
[/quote]
KO
- 5895 Views
Last post by tiger1
- 32 Replies
- 3774 Views
Last post by MOmo
- 1578 Views
Last post by Mindwarp
- 21 Replies
- 2663 Views
Last post by TRX-1-3
- 62 Replies
- 6262 Views
Last post by slotcarrod
- 1753 Views
Last post by morrisey0
- 2112 Views
Last post by Frankentruck
- 1343 Views
Last post by WriteDean
