RC10 Edinger Fire Rescue
Has thanked: 355 times
Been thanked: 470 times
Re: RC10 Edinger Fire Rescue
The chassis looks great. Rod, I'm sure this is painful...but it's a process. If I can help with ANY parts for the restoration if the nylon isn't salvageable etc, please let me know. I'm pretty damn sure that I'm not the only one who would donate parts to see this Phoenix rise.
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
Thanks Reg, it's just tough to look at! I'm not looking for any hand outs, but I would like to purchase a set of rear GoodYear tires and a gear cover if any members can help with those?
This is the car before the fire but with a box art painted body on it during the fire: http://www.rc10talk.com/viewtopic.php?f=35&t=8017
This original body is safe! 8)
vintage AE
Has thanked: 29 times
Been thanked: 36 times
Post by vintage AE »
I'm getting a bit more work done on the tear down. Most of the car is now apart and ready for cleaning, sanding, polishing, bleaching or whatever may come to each part. Reg, I haven't tried the shock therapy on any nylon parts yet, but probably will give it a try on the other car to see what happens and if it's worth while. I'm actually just being lazy about getting the distilled water.
You can tell where the out drives were exposed that's for sure.
These shocks have seen better days, I can't wait for the after shot.
SiRacer420
Post by SiRacer420 »
I got this gear cover from another member when I traded some stuff. If it's the correct one for this, someone give me an address to send it to.
vintage AE
24 hr soap treatment on the remaining aluminum parts... I threw the springs in to see what would happen, which was nothing but just cleaning them. The shock bodies and motor plate turned out really nice though.
A little shock and awe therapy. I was only giving 5 minutes in each at a time, but I should be leaving them 10-15 minutes. I'll try again tomorrow since I didn't have too much success this evening.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Charlie don't surf wrote:The chassis looks great. Rod, I'm sure this is painful...but it's a process. If I can help with ANY parts for the restoration if the nylon isn't salvageable etc, please let me know. I'm pretty damn sure that I'm not the only one who would donate parts to see this Phoenix rise.
Just say the word :!:
slotcarrod
That gear cover looks right but I think its milky later one. The Edinger early cover is clear. Thank you for the offer, if it's clear I will for sure buy it!
SiRacer420
Yeah it's definitely translucent not clear. I'll keep an eye out for a clear one. If I find one, it'll be donated.
duckhead
Has thanked: 162 times
Been thanked: 205 times
Post by duckhead »
Looking good!!
Are you simply boiling the parts in water for 5-15 minutes, or using chemicals too?
Assuming the ice bath afterwards is to rehardened/seal the nylon after boiling?
->Mark
vintage AE
I'm just using distilled water for boiling, no chemicals. The idea is to open and close the micro pore spaces or expand and contract the surface of the nylon so the staining comes off. Nobody has tried it before on fire damaged parts, but it's been used before to remove dye.
CamplinP
Post by CamplinP »
As far as parts go that can't be refurbished, I think a running list of parts needed would be a worthy cause.
R Cane
Has thanked: 159 times
Been thanked: 64 times
Post by R Cane »
CamplinP wrote:As far as parts go that can't be refurbished, I think a running list of parts needed would be a worthy cause.
x2
A lot of work.
But it looks like it's coming along well considering the damage.
8)
vintage AE
I would have Rod confirm this, but I think the only parts he doesn't have are the tires and gear cover. I'm sure other parts will have to be replaced, but he has spares.
So here is the result of shocking the parts... it did not remove the discolouration from heat damage, and also removed the melted section of this rear arm that got too hot.
The towers will have to be bleached sanded too. If that doesn't work, then they will have to be replaced.
slotcarrod
All the anno parts look like they came out nice. I am sure bleach will do the trick for the nylon and towers. Then a boiling to get rid of the bleach, and a gentle slow boiling in tea to bring back the original colour!
Farabomb
Post by Farabomb »
As someone that also had a house fire I hate to see that look in the initial pictures. Luckily I didn't have any of my RC cars in the room that burned but I did loose a CG8 WRC Tamiya static model. It's great to see you resurrecting it. After cleaning my room of junk and finding my OG RC10 I may get motivated to clean it up.
When in doubt, throttle out. It may not help the situation but it will end the suspense
RC: Org RC10 ReRe RC10 Worlds RC18T RC18B RC18R SCX10 Wraith MREV T-Maxx Subaru Brat Blackfoot QX180 ProtoX PFV and Nano
Crewchief for AZPInstalls BRZ PTD racecar
