Moderators: scr8p , klavy69
durb69
Posts: 384 Joined: Wed Mar 07, 2012 12:55 am
Been thanked: 5 times
Post
by durb69 » Thu Oct 01, 2015 9:03 am
Oh, I know I can pull it off, it's just a matter of when lol.
here is more pics of the body.
RC10th
Posts: 4761 Joined: Sat Feb 16, 2013 9:51 am
Has thanked: 52 times
Been thanked: 1548 times
Post
by RC10th » Thu Oct 01, 2015 9:49 am
That's pretty cool, a flat sheet folded up like that.... Nice work.
durb69
Post
by durb69 » Thu Oct 01, 2015 10:08 am
Thanks. Bending it is a huge pain. But I did it!
askbob
Posts: 1736 Joined: Sun Apr 03, 2011 11:24 am
Been thanked: 4 times
Post
by askbob » Fri Oct 02, 2015 9:10 am
DAMN that is cool!!
Posts: 6580 Joined: Wed Jan 28, 2009 9:42 am
Has thanked: 16 times
Been thanked: 505 times
Post
by jwscab » Fri Oct 02, 2015 9:40 am
like an EDM, but a buggy
durb69
Post
by durb69 » Tue Oct 13, 2015 11:26 am
fastang
Posts: 751 Joined: Mon Aug 04, 2008 7:53 pm
Post
by fastang » Tue Oct 13, 2015 6:52 pm
Now you need to find those clear shock bodies. I forget who made them.
limestang
Posts: 990 Joined: Tue Sep 27, 2011 9:48 am
Has thanked: 100 times
Been thanked: 249 times
Post
by limestang » Tue Oct 13, 2015 11:45 pm
Hammad Ghuman - They would look great on this build!
durb69
Post
by durb69 » Tue Oct 13, 2015 11:47 pm
I've already located a set from an OSRC member, Waiting on them now.
durb69
Post
by durb69 » Tue Oct 13, 2015 11:49 pm
I tried machining one already, not N easy task. I screwed up the first one. It's cheaper to buy a set.
RC10th
Post
by RC10th » Wed Oct 14, 2015 6:28 am
Make sure the shock piston/shaft don't hit the cap before the shock bottoms out. If it does you'll need to use up travel limiters otherwise the piston/shaft will punch the caps right off.
If this is solely for display only disregard this message which will self destruct in 5 seconds...
durb69
Post
by durb69 » Wed Oct 14, 2015 1:59 pm
Thanks for the heads up! This car is going to be ran, for sure. Ill also be making more once i finish this one. Should have the clear shocks in a week or two I think.
esaresky75
Posts: 332 Joined: Mon Jan 24, 2011 9:09 pm
Post
by esaresky75 » Thu Oct 22, 2015 2:17 am
limestang wrote: Excellent work as usual!
The lexan chassis gives a new dimension to Stealth:)
He never said its lexan, I think he got his hands on some transparent aluminum.
Burn more coal - UnderGroundMiners.com
durb69
Post
by durb69 » Thu Oct 22, 2015 11:36 am
Yes some space age NASA top secret clear aluminum
Yeah it's lexan.
DMAT
Posts: 885 Joined: Wed Mar 20, 2013 8:53 am
Post
by DMAT » Thu Oct 22, 2015 2:41 pm
ive been curious what you've been working with too
hope you give that transmission a test run, hoping to hear the gears fit in it right before I incorporate the model with something else.
Last post by tazz888
Sun Aug 10, 2008 10:24 pm
Last post by juicedcoupe
Mon Jul 24, 2023 8:13 pm
Last post by JK Racing
Tue Oct 07, 2014 12:59 am
Last post by lowrydesign
Fri Aug 28, 2009 2:08 pm
Last post by y2kgtp
Thu Mar 05, 2009 5:40 pm
Last post by nbrophy
Sun Apr 30, 2023 12:33 pm
Last post by Chewbacca
Mon May 26, 2025 5:49 am
Last post by Booa
Fri Nov 20, 2020 2:43 am
