Back in Time - XLS For Vintage Racing
Groomi
Re: Back in Time - XLS For Vintage Racing
Post by Groomi »
Thanks, I'm happy with how they turned out. :)
The total length is the same as the numerous sets of original Schumacher shocks I have, but the longer body means they have less travel. This may or nay not be an issue, but they're definitely smoother.
Regarding the finish, the pics do flatter them a bit. One of the rears in particular was badly pitted.
Using my son as an excuse to relieve my youth. :lol:
https://www.facebook.com/MuzzoomModels
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
The Pro Cat manual suggests to put a 6mm peice of tube to step up the lower spring retainer on the front - so effectively restricting the travel of the shock, I'm sure the same amount of movement can be replicated with added internal limiters & less (or no) added spacers beneath the spring retainer with using the Kyosho shocks. When I build up my std Schumacher shocks I will try & determin what is needed to get the same movement with the Golds.... Since the latter do operate more smoothly :D
Groomi
Post by Groomi »
Ah, that's good to know. That should give about the same amount of travel at the front then.
Groomi
Post by Groomi »
Right - time to get this party started!
Peakey
Post by Peakey »
That picture shows just how anal we all are about vintage cars :lol:
Ps very nice can't wait to see it finished and here how you get on with i.
DerbyDan
Post by DerbyDan »
Great Photo Groomi.... tantilising :P
I took an equally anal pic just before final assembly of my Masami Yokomo;
http://www.tamiyaclub.com/pictureframe.asp?t=n&id=img28990_25102011155226_1.jpg
Groomi
Post by Groomi »
:lol: Thanks guys.
Peakey
Post by Peakey »
DerbyDan wrote:Great Photo Groomi.... tantilising :P
Now that's next level dan :shock: :lol:
Groomi
Post by Groomi »
Trinity rear diff just prior to assembly. Alloy outdrives have internal bearings and I'm using a pro thrust bearing with four cone washers.
Groomi
Post by Groomi »
Assembled rear diff with completed MMS front diff. Nylon outdrives, again with pro thrust bearing and four cone washers.
Groomi
Post by Groomi »
Transmission sideplates assembled with MMS alloy eccentrics and PBK alloy layshaft bearing holders.
Peakey
Post by Peakey »
Shiny :shock: what did you use
Groomi
Post by Groomi »
They were a mess to start with, so I used decreased, 1200 wet and dry, 3 grades of wire wool pads on the Mouse and then some manual polishing with metal polish and finally a bit of Brasso.
No effort at all!
Peakey
Post by Peakey »
It's all worth the effort in the end. What's that heatsink I have a mms one similar but it's black and a different shape
Groomi
Post by Groomi »
No idea who made the heatsink unfortunately. I also have an MMS one, but it looks like somebody got hungry ans started to chew it...
Return to “Schumacher Forum”
