B3 Tyres on Worlds Car Parts
General info, Q&A.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: B3 Tyres on Worlds Car Parts
Post by JK Racing »
AYKBOBCAT wrote:So what are the yellow front on the buggy on the picture? They match with the Jammin's rears...
The fronts are standard B2/B3, I had a pair, for racing it will be fitted with B4 fronts. The link you posted is for the CRT rims I am using for the rear.
JPAE07, I believe you are right.
Aussie Al
Post by Aussie Al »
JK Racing wrote: The Jammin's are great. Just mounted a set today. They are 2.2, and with the HPI adaptors, they fit just fine. If you want an easy/cheap way to mount current tires to old RC10s, I feel this is the best bet...
Thats awesome. What is the part number for the HPI Adaptors?
JPAE07
Post by JPAE07 »
AYKBOBCAT Asked the following:
These are the tires and wheels to use?
http://www3.towerhobbies.com/cgi-bin/wt ... LXCXT5&P=7
http://www3.towerhobbies.com/cgi-bin/wt ... LXCXT7&P=7
http://www3.towerhobbies.com/cgi-bin/wt ... LXCXT3&P=7
http://www3.towerhobbies.com/cgi-bin/wt ... LXCXT2&P=7
I didn't see a response so I am asking again.
Does anyone know or has anyone tried these Evader BX2 rims on their B2 axle conversion?
I checked the DuraTrax website and instruction manual for the Evader BX2 and it looks like thee rear axles use pins, So the backs of the rears should work. Does anyone know?
Thanks
JK Racing
Post by JK Racing »
I cant get those links to work. I havent tried the Duratrax wheels, and am happy with the CRT ones. I still need to get a set of B2/B3 cvds....projects, projects, projects.
JPAE07
Post by JPAE07 »
AYKBOBCAT wrote:Restarting this post...
I need tires and wheels for my T2 chassied buggy...
I used this CVD kit
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAV59&P=ML
So I get that I could use evader wheels and tires?
these are 2.125 wheels right? (2 and 1/8). Is this the same as 2.175 from associated?
Do I have to stick with Duratrax tires?
Do the front wheels use only metric bearings?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCXT5&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCXT7&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCXT3&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCXT2&P=7
Here it from the first page of posts.... The links should work.
JK Racing
Post by JK Racing »
My personal opinion is that the offset is closer to the B4/Losi that needed for our vintage cars. Only way to really tell is to pick up a set.
dangermouse
Post by dangermouse »
The rear duratrax rims shown in the previous post wouldn't work. They are from the electric evader bx.
You would want rims from the nitro evader bx as they have a deeper dish, probably closer to what you would want for an early rc10.
The only problem with the duratrax rims on a runner is they tend to chip/crack easily around the outer rim.
JPAE07
Post by JPAE07 »
Damn. I saw the offset looked a bit different but was hoping they would work. I pictured a set of Green or Blue Evader BX2 wheels on a new B2 conversion. Oh well.
dangermouse
So long as you use rims from a NITRO evader bx, you should be good.
The following should work:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFFG4
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFFG5
JPAE07
Post by JPAE07 »
Thanks danger,
I'm gonna order a set and see if it works.
Users browsing this forum: No User AvatarAmazon [Bot], User avatarcarloco8 and 5 guests
