By the way are your alternative LRM diff bearings, part # A-6901, 3/32" thick or 1/8" thick??? The ones I have are the wrong size and cause the diff to bind.
Do the thin SS bearings that measure 3/32" thick still exist or are they nearly impossible to obtain?? I guess the alternative is to slightly ream out the male and female diff halves to accommodate the thicker bearings.
Been waiting on some 8x14x4mm bearing to arrive.......and now they have , some more progess will be made on the build, oh yes! Update and photo's to follow....
I decided to use the XXX rebuildable Universal Bearing Cross, part # A-3027 because I hate pliers..... ....and besides, they're much easier to work with.
Slider drive shafts.
Losi Jr.2 Update 029.JPG (114.91 KiB) Viewed 1980 times
Up close...
Losi Jr.2 Update 031.JPG (102.15 KiB) Viewed 1980 times
Up close...
Later all black axles.
Losi Jr.2 Update 034.JPG (94.92 KiB) Viewed 1980 times
Fitting the female halves of the slider shaft to the out-drives.
Fitting the female half to the out-drive.
Losi Jr.2 Update 035.JPG (104.03 KiB) Viewed 1980 times
Using a little thread-lock on the set-screw......remember, a little goes a long way!
Thread-lock the set-screw.
Losi Jr.2 Update 036.JPG (98.39 KiB) Viewed 1980 times
One LRM gearbox ready for installation.
All done.
Losi Jr.2 Update 040.JPG (103.24 KiB) Viewed 1980 times
All done.
In it goes!
Losi Jr.2 Update 043.JPG (117.26 KiB) Viewed 1980 times
In it goes!
Side view.
Losi Jr.2 Update 044.JPG (107.65 KiB) Viewed 1980 times
Side view.
Ahhh! Progress....
Ahhh! Progress....
MARVELOUS mention!! Appreciated. Added to my must have list. Thanks again.
Great work btw! i been trolling your build. MORE please.
For using the flanged bearings did those red steering arms have a fitment for them? I have a red set but it does not have bushing space at all...supposed to just slid into posts flush.
Sorry, almost forgot.....regarding the steering arms, yes the ones that I have, have a recess to accommodate a flange - hence my reason for using them. If you're interested, here's a link to the bearings that I used:
Here's where the project sits right now. Front shocks have been installed (dry at this point) as have the front tie-rods and camber links using some Lunsford Titanium turn-buckles and RPM short ball cups. RPM HD side bulkheads have been fitted in the hope that I can get to finish off the 5-Link rear suspension and finally the hard-to-find RPM Hydra-Drive gear cover has also been installed.
I'm also on the lookout for the RPM chassis brace as this has a much nicer look to it (IMO).
Progress so far...
Losi Jr.2 Update 001c.jpg (124.91 KiB) Viewed 1878 times
Progress so far...
Front shocks installed (dry at this point) with RPM Losi top shock mounts courtesy of eBay.
Losi Jr.2 Update 002c.jpg (121.57 KiB) Viewed 1878 times
Oh, yes....I dyed the wheels black BUT only the fronts as I had a spare set.
Losi Jr.2 Update 003c.jpg (121.44 KiB) Viewed 1878 times
Rear end dilemma. RPM HD Bulkheads installed.
Losi Jr.2 Update 006c.jpg (127.87 KiB) Viewed 1878 times
The rear H-arms have been assembled but at this point I'm still not quite sure which way to go. I would love to go 5-Link but the absence of part # A-5010 puts me off as I don't want to have the Jr. sat around unfinished waiting for the lower rear shock mounts to appear.....I guess I can but live in hope!
H-Arms ready to go...
Losi Jr.2 Update 013c.jpg (116.62 KiB) Viewed 1878 times
Axle close up showing the use of XX part # A-9941...
Losi Jr.2 Update 015c.jpg (121.98 KiB) Viewed 1878 times
