Modernizing your RC10 - question regarding electronics
General info, Q&A.
mdutcher
Re: Modernizing your RC10 - question regarding electronics
Post by mdutcher »
kaiser wrote:back to the question at hand, power/gearing.
you want to run a 10.5(4200kv) motor (i wouldn't use castle, but thats your call).
using novaks final drive chart http://v2.teamnovak.com/kb/knowledgebase.php?act=art&article_id=29
you want to be at a final drive of 8. using a 81 tooth spur you'll need a 22 tooth pinion.
keep in mind that this is a starting point, you can go up or down as needed just monitot temps.
you don't want a 540 sized bl motor to hit the 170 range.
Ok, thank you for the advice as I do appreciate the feedback. I am merely starting out with the 3800kv motor and I will go from there.
I too was thinking that I am shooting for an 8 FDR, but the 22 is not correct per the calculation. I think that it should be like a 27t pinion. 81/27 = 3. 3*2.65=7.95. Would you not agree??
I will definitely be monitoring performance, heat, etc when running the castle. I may switch to something later down the road, this is merely my starting point.
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
mdutcher
Post by mdutcher »
kaiser wrote:fred is that a hobbywing motor? most 8.5's are around 5000kv.
i find 10.5 the perfect mod motor for 2wd. i tried a novak 8.5 (5000kv) and it was crazy, but the 10.5 seems just right.
I just bought a Reedy Sonic 10.5t for my B4.1 and am anxious to give that a spin. Currently running a 13.5t in it right now. If I like the feel of the 10.5t, than I might make the switch in my Worlds if I don't like the feel of the Castle.
kaiser
Post by kaiser »
oh, i was figuring off a 2.25 stealth, i didn't realize that you are running a 2.65.
Post Reply
  • Resurrecting/Modernizing Your Vintage R/C's Electronics
    by scr8p » » in Modern Electronics
    Last post by bigrobbyt
  • Modernizing the RC10 hubs with SC10, B4, and other parts
    by shoman24v » » in Temple's RC10 Tech Forum
    Last post by covell2
  • Modernizing RC10 Team Car (#6035)
    by steph » » in RC10 Buggy Forum
    Last post by steph
  • new electronics for RC10
    by mercdog » » in RC10 Buggy Forum
    Last post by Zedmaster
  • RC10 CE rebuild electronics
    by BooGTS » » in Modern Electronics
    Last post by BooGTS
  • RC10 Team Car Revival - Updated w electronics, short video
    by frgna » » in RC10 Buggy Forum
    Last post by erichevy
  • WOIN RC10 Sprinter... with "modern" electronics
    by SoAzRC » » in RC10 Buggy Forum
    Last post by THUNDERSTRIKE1
  • modernizing a "brick" (jerobee/jomac)
    by GoMachV » » in Other Makes/Models
