Discussion about possible aluminum transmission and parts
aoH
Re: Discussion about possible aluminum transmission and part
Post by aoH »
klavy69 wrote:
aoH wrote:are these still aval?
Yes they are. At this point it looks like you have to have b/s/t access to get them. That is where 300D50 has his link to these. You can pry pm him to see if he wants to let one go outside of the b/s/t area.
ahh, that explains that.
thanks!
300D50
Post by 300D50 »
As of now, they are on intergalactic back-order...
The machine I've been using got put into service for a different production run, so I have to wait it out.
I'm sitting on too much stock and tooling to up and leave, but there may be a significant delay before they are back on the market.
Seems like it's always two forward, one back for me.
Walt
Some people never have anything except ideas. Go do it.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
Walt, glad to hear from you. Sorry to hear about you having the same kinda luck I have :wink: . Right now I'm in the 2 steps back phase myself. Keep us posted when you get back up and going.
I think I have enuf to get a white one now :mrgreen:
Has thanked: 3699 times
Been thanked: 1980 times
klavy69 wrote:Right now I'm in the 2 steps back phase myself.
Yeah?? Well I blame both of you for getting Paula Abdul stuck in my head... :evil:
klavy69
Moderator
Post by klavy69 »
well if thats all thats stuck in your head then I guess it ain't all that bad :mrgreen:
300D50
Post by 300D50 »
"love in an elevator" and the movie "cool world" are stuck in my head after seeing that sig.
Walt
bully
Been thanked: 6 times
Post by bully »
Mate a case that is direct bolt up fit with RC10 stealth cars but using the internals from the B4,T4 FT would be sweet as mate i would grab at least 2
Jeep-Power
Has thanked: 56 times
Been thanked: 52 times
Post by Jeep-Power »
bully wrote:Mate a case that is direct bolt up fit with RC10 stealth cars but using the internals from the B4,T4 FT would be sweet as mate i would grab at least 2
It does seem like a great idea at first. I was hoping for the same.
There is a catch with doing this.
The late model diff gears have a larger diameter. This means that the vertical centerline of the outdrive will be significantly higher/further away from the top surface of the chassis.
That means that the stock/OEM length dogbones will be too short. Either the upper swingarm mount will have to be raised significantly or custom length dogbones will have to be made.
With this issue, it is clear why AE now has the bottom of the trans case pierced through the chassis. Doing so helps keep the driveline lower in the chassis & therefore gives better dogbone angles.
I am currently planning on going through the bottom of the chassis, with a late model transmission, on my next build.
TallPeter ~ Hopeless Gearhead
Early Goldpans 'Fun Buggy' RC10C B44.3 RC8B3.1 RC12l 10LS Pro10
bully
Post by bully »
Thought the extra length in the bones would be minimal and you would be able to get around that buy playing with the wheel axle spacers.
CUDDZILLA
Post by CUDDZILLA »
When you're back in production, I'd be interested in a 6 gear just for gits and shiggles.
Jeep-Power
bully wrote:Thought the extra length in the bones would be minimal and you would be able to get around that buy playing with the wheel axle spacers.
possibly, but I don't think so. I want as much suspension travel & droop on my buggy as I can get.
If the rear suspension is set up very flat, so the dogbones are almost always in plane with the outdrives, then, yeah.
I had to shim my rear suspension blocks when mixing parts from a 10T & 10. They both had the 2.25 stealth. 1/16" of shims made all the difference. The dogbones were jumping out otherwise.
bully
Post by bully »
Looks like we may have to get someone to mill down the B4 outdrives to suit the 2.25 diff gear and rings then seeing as the oe 2.25 ones are very hard to find now.
if you didn't want to cut a hole in the chassis, you could make a plate under the trans and rear arm mounts to put them in the same plane and actually lower the CG a bit.
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
bully wrote:Looks like we may have to get someone to mill down the B4 outdrives to suit the 2.25 diff gear and rings then seeing as the oe 2.25 ones are very hard to find now.
Y not make a trans case to house all the b4 internals in the stealth layout ?
klavy69
Moderator
Post by klavy69 »
lowrydesign wrote: Y not make a trans case to house all the b4 internals in the stealth layout ?
