Discussion about possible aluminum transmission and parts
300D50
Re: Discussion about possible aluminum transmission and part
Post by 300D50 »
I also have another sample part ready, in case there's another person willing to preorder.
Walt
Some people never have anything except ideas. Go do it.
Toasted Coastie
Post by Toasted Coastie »
patiently waiting production run......
300D50
Post by 300D50 »
Just ordered 2 feet each of black and white Delrin (and yes, I got Delrin brand acetal...).
Should be in soon, and then I can see how bad it machines... yippee...
Walt
300D50
Post by 300D50 »
Ack, double-post.... eeekkk...
Here's the link to the numbers-getting thread in BST.
http://www.rc10talk.com/viewtopic.php?f=6&t=22612
Walt
treehugger
Post by treehugger »
Ok i ran 5 packs through the trans ,on the truck slipper tight ish
on around the 5th pack the lower motor screw dropped out twice once is i messed up but after another five mins same thing .
as i have never had to thread lock a metric motor screw before i stripped it down to find the bearings took a dump. ( they were new blue rubber sealed ) so rebuild tonight i have oem unsealed that came with gt trans this time plus a different set of gears .Good condition used .
i hate to make any calls on the bearing tolerances ,so this time i will mark both main bearing shells on one side to see if there was any slippage, as it looks like one of the sealed bearings might have rotated weather before or after they failed is the question :?:
Paul
300D50
Post by 300D50 »
The small chunks of Delrin came in Tuesday, I'll be doing a prototype or two Tomorrow. If they machine better than aluminum (no chatter, etc, which I think will be the case), I'll make the Delrin run first.
A lot of things are coming together right now, life feels good. :D
Walt
treehugger
300D50 wrote:The small chunks of Delrin came in Tuesday, I'll be doing a prototype or two Tomorrow. If they machine better than aluminum (no chatter, etc, which I think will be the case), I'll make the Delrin run first.
Hey Walt good to here :D
How much are the small chucks ? do you want to sell me another proto ? same resell rule :wink: which wont happen LOL as i love the alloy one .
should work out nice ill send the alloy one back for your inspection including all the moving parts used, . i would think the delrin would be far more forgiving on the press fit tolerances than the alloy .but im sure with the nicely rising numbers in the BST you will be ready to put this to bed .
let me know and ill adjust the total for the remainder owed .
i have had no problems since i changed to regular unsealed bearings i used a couple of tiny tooth pick tip blobs of threadlock 8) on the main bearings only
SO lol now i want to do the sealed again :roll: with the thread lock blobs.
i like the sand and sea always been round it ,so sealed is the way really .
regards Paul
300D50
Post by 300D50 »
I found the problem...
The bearing bores on the housing that you got were .0015 over instead of .0005 over... Didn't catch it because I never threw it on the CMM to verify...
It's been rectified.
Walt
300D50
Post by 300D50 »
And another double-post...
Delrin will be the first production run, it's machining perfectly.
Also plopped down for another 3 flute endmill in 1/8", this one with a TiCN coating, supposedly better than TiN for aluminum.
It's also going to be here Friday afternoon instead of the middle of next month...
Walt
300D50
Post by 300D50 »
Triple post...
Original housing weight is 16.79g
Delrin is 18.53g with the dowels (I didn't think to weigh just the dowels... forgive me...)
I'll be sending this one out to be torture-tested, once everything is known to be good, it'll be production run of the remaining Delrin stock.
Walt
Jedi Master
Post by Jedi Master »
Can't wait to order these!!! :D
Do, or do not! There is no 'try'!
RC; Boats, Buggies, Trucks, Bash's, Racing and of course 'VINTAGE'!
My Ebay Feedback: http://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=jedimaster768&ftab=AllFeedback
Has thanked: 355 times
Been thanked: 470 times
Come on white Delrin!!!! :lol: , I race my RC10 weekly as does my 6 year old :wink:
m_vice
Post by m_vice »
That looks awesome, now I want a Delrin in addition to the aluminum one.
treehugger
m_vice wrote:That looks awesome, now I want a Delrin in addition to the aluminum one.
and of course how can you have a black one with out a white one !!! :lol: :lol:
SnoopMaxx
Post by SnoopMaxx »
300D50 wrote:Triple post...
Oh my :shock:
Don't you just love how well Delrin machines ! ! !
Did you get the white Delrin too ?
Morten
Morten Max
