hey do you have a link to get the IFW2?Brandon G wrote:This may or may not help you.
Kyosho still has the M, L, and LL turnbuckles in stock. I think they are UM-12, 13, 14. UM 11 is the short one and is hard to find. However if you don't mind silver, IFW2 is the same length and style, just different finish.
Also, HPI carries a lot of the same style screws that were originally on the Ultima. Phillips, steel, same finish. May have to trim to length on the gearbox screws tho.
are you sure the KYOSHO INFERNO TIE ROD are the same size as the ones for the Ultima, Optima...?
