Klunker Gone Wild, New paint PAGE 4
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: Klunker with a facelift
Regarding those Losi a-2038 rear hub carriers Doc J33p had 4 up for sale a week ago. Why don't you check with him they might still be available:
http://www.rc10talk.com/viewtopic.php?f=6&t=9764
This is all very interesting!
- a01butal
A & L made CF chassis stiffeners bitd which is probably where the idea originated, they are very difficult to find and expensive so it looks like a simple L shaped piece of material maybe aluminum or CF which might be available at McMasters Carr or some place like that. If you can tie it into the front battery mount midway then it really does the job.
Aluminium tubing covered in black shrink sleaveRedScampi wrote:What are the chassis stiffeners made from?
I tried to look at the page to see if I could buy them. But I don't have access?a01butal wrote:Regarding those Losi a-2038 rear hub carriers Doc J33p had 4 up for sale a week ago. Why don't you check with him they might still be available:
- a01butal
I sent Doc a pm so maybe he will contact you.
He did, thanks for the help.a01butal wrote:I sent Doc a pm so maybe he will contact you.
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
That's a nice looking klunker. Glad to see your arms came out good. I'm still debating on dying mine. I'll finally get to finish my build by the end of the month.
Keep us in the loop with how you make out with your new hubs.
I should have let you know, but I forgot. Those turnbuckles you gave me the part numbers for worked great.vintage AE wrote:That's a nice looking klunker. Glad to see your arms came out good. I'm still debating on dying mine. I'll finally get to finish my build by the end of the month.
Through the help of a01butal. I have located some Losi hubs. That should have my CVA problems fixed.
- vintage AE
did you have to trim your rear turnbuckles with those losi hubs???? Maybe I'll get him to hook me up with a pair too?chris72983 wrote:He did, thanks for the help.a01butal wrote:I sent Doc a pm so maybe he will contact you.
oh, and can you us the same bearing with those?
- Has thanked: 36 times
- Been thanked: 1318 times
for the record, there's nothing wrong with the rpm carriers. i just like the 2038 hubs because there a ton of camber placement options. if i remember correctly, when david and paul built theirs, they had to drill a hole higher in the bulkhead to get the suspension to work the way they wanted to. you won't have to do that with the losi hubs.
- vintage AE
Hey scr8p,
I prefer the losi hubs too, but if I cant find any I may have to go with the rpm hubs. Do you happen to know the part number for the rpm hubs?
it looks like 70272. that's just for the carriers.
http://www.rpmrcproducts.com/products/assoc/rear.htm
I just decided to use the Losi hubs, so that I could use the bearings I already have and for the camber links. I just felt they will be a easier fix for my camber and cva problems.scr8p wrote:it looks like 70272. that's just for the carriers.
scr8p, I thought that I was posting this message a minute ago. And I think I must have hit the report button and entered my message in the reason box. Sorry about that.
chris72983 wrote:I made and installed these stiffeners. I didnt realize how much they were need after I cut the chassis lip down that much until I installed them.
scr8p are these the hub carriers?
RC10T & GT Carriers
These carriers are exactly the same as #7023 without the 1/4" x 1/2" bearings. Combined with #7028, this set will accommodate 3/16" dia. axles on your RC10T or GT.
70272 RC10T, GT Carriers (T2, & T3 when used with #7028 for 3/16" axles or #7024 for 1/4" axles)
Suggested Retail $7.95
Above Pulled from RPM site.
What did u use for the chassis stiffners? And to stripe the anodized Aluminum chassis?
One mans junk, is another mans treasure!!
I used aluminium tubing for the stiffners, and to strip the chassis, I just stuck it in the bead blaster at work and blasted it off.
amx73 wrote:chris72983 wrote:I made and installed these stiffeners. I didnt realize how much they were need after I cut the chassis lip down that much until I installed them.
RC10T & GT Carriers
- 1162 Views
Last post by Lonestar
- 620 Views
Last post by bscotti
- 2926 Views
Last post by hugger19
- 19 Replies
- 1799 Views
Last post by DPero
- 467 Replies
- 196683 Views
Last post by jcwrks
- 3491 Views
Last post by NomadRacer
- 1308 Views
Last post by trek
- 34 Replies
- 4169 Views
Last post by shodog
Users browsing this forum: Ahrefs [Bot] and 8 guests
