My projects
Roadrashracing
Re: My project
Post by Roadrashracing »
It there an area here with setups?
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: My project
Post by Mr. ED »
Roadrashracing wrote:Ran it for the first time tonight, ended up using my better radio and a new r/x. It handled better then my bk2 ever did.
Good for you!
I think the associated site has some set-up tables (just guessing)
What moter did you run?
Roadrashracing
Re: My project
akk i could find was blank setups
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: My project
Post by JK Racing »
I believe there was some setup talk before the nats in the old "general" forum. Take a gander that way...
Roadrashracing
Re: My project
I looked in a few spots an could find nothing
JK Racing
Re: My project
Post by JK Racing »
Took me a little while, but found it:
Mark Westerfield wrote:Mark Westerfield's
2008 Vintage Off-Road Nationals @ Radio Control Hobbies & Raceway, CT.
1991 RC10 Team Car Setup
Front
Shock Body: .71
Shock Shaft: .71
Travel Limiter: None
Piston: #1
Oil: Asc 40wt
Spring: Green
Shock Upper Mount: Top Middle
Shock Lower Mount: Arm Outside
Camber Link: Inside
Camber: -1.5 Degrees
Castor: 30 Degrees
Toe-In: 0 Degrees
Bump Steer: 2 x .030 on steering block
Bellcrank Type: Houge Ball Bearing
Steering blocks: Inline
Front Axle: T4 Inline
Ride Height: 22mm
Wheels: RC10B4
Tires: JConcepts Rounders
Inserts: JConcepts Standard
Rear
Shock Body: 1.32
Shock Shaft: 1.32
Travel Limiter: 3 x .125
Piston: #1
Oil: Asc 35wt
Spring: Green
Shock Upper Mount: Inside
Shock Lower Mount: Outside
Camber Link: Inside Under Wing Mounts
Anti-Squat: Std (3 Degrees)
Toe-in: 1.5 Degrees On Mount, 1.5 Degrees On Hub Carrier
Wheelbase: Short
Rear Axle: MIP RC10 CVD's W/RC10B4 CVD Axle, B4 wheel spacers, 3/8 x 3/16 Flanged Bearings
Ride Height: 22mm
Wheels: Duratrax Nitro Evader
Tires: JConcepts Double Dee's
Motor: Novak 17.5
Gear Ratio: 28/81
Battery: Orion 3200 Lipo
Speedo: LRP Sphere Competition
Settings: 1-4-1-3
Servo: Airtronics 94357
Body: Asc Viper
Wing: Asc 6.5 w/ Full Spoiler
Other tips...
If using the graphite trasmission brace, make sure the .060 washers are between the the bulkhead and brace. Use a striaghtedge to make sure the chassis is striaght across the bottom for correct front kickup and rear antisquat. Add shims between motor guard and chassis to correct antisquat. Use short neck ballstuds on steering rack and front shock tower to eliminated ballcup contact. Final tuning on these cars is mostly done with shock limiting and ride height adjustments.
Roadrashracing
Re: My project
hey I will add it to what I was doing thanks
Roadrashracing
Re: My projects
here is my new project
came with lots of goodies box and manual
fastang
Re: My projects
Post by fastang »
I love graphites! I just paid way too much for that new in opened box one that was on evilbay last week. I'm getting a $1000 bonus at work for not drinking for 1 full year, so I figured Id treat myself to something nice!
Roadrashracing
Re: My projects
All my cars are getting torn down and rebuilt. The RC10 Graphite is going to get a modern look, I am going to put the stealth trans from my gold into here and make this my modern race buggy. I also got a graphite oval chassis that my gold tube parts are going with the 6 gear trans.
