need help!! who makes these wheels????
MONSTER
Re: need help!! who makes these wheels????
Post by MONSTER »
This is the, as of yet, uncleaned Rears that came on the Yellow RPM 10T I got on ebay a while back. I think they will clean up nice.
The Fronts were dyed Yellow (Temple informed me they only came in White and Chrome), but I recently aquired a NIP Set of Fronts, in White, for pretty cheap on eBay. So, I now have full Set of White, and an "extra" Set of Fronts in Yellow.
aeiou
Post by aeiou »
scr8p wrote:does anyone know the part number for the rears?
That'd be 2573 (or 2573C for the chrome rears).
now the fronts are the same for the 10t/lxt. but the rears for the lxt would have a different part number because of the difference in the axles, right? anyone know that number? i would think the backspacing would be the same between the 2, so if you'd put 3/16 axles in a 10t you should be able to use the lxt rears, no?
call-911
Post by call-911 »
Keith C
MONSTER
Post by MONSTER »
call-911 wrote:Lookadis
Same Guy I got mine from. Great transaction, fast shipping.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
Velocity is close to Aero-Dish right :oops:
templeofspeed
Been thanked: 33 times
Post by templeofspeed »
scr8p wrote:now the fronts are the same for the 10t/lxt. but the rears for the lxt would have a different part number because of the difference in the axles, right? anyone know that number? i would think the backspacing would be the same between the 2, so if you'd put 3/16 axles in a 10t you should be able to use the lxt rears, no?
I've got the LXT rears, same backspacing as the 10T, just setup for 3/16" axles (so they'll work with T2/T3 axles). I'll dig up the p/n for ya.
Sure, just 7 or 8 years different... :wink:
adam lancia
Sure, just 7 or 8 years different... :wink:[/quote]
OK, along the same theme at least 8)
extreemduster340
Post by extreemduster340 »
By far my favorite aftermarket 10T wheels as you can see from the pictures. Recently I scored 2 complete sets of chrome ones for rubber tires :D There going to look great for one of my shelf queens. I also have a set of white front with foams mounted and front rims for foam, need to find white rear foams. I also have about 4 sets of rear white's with tires mounted, but I need white fronts for rubber tires. Would love to find a set of those front narrows, but it is going to take some time! Might try and demount some of the rears to use on a runner as the older tires are very hard even though they are in excellent shape. Only problem with some of the white rims is that they are yellowing as the years go by, even inside the house. I also took a picture of the original add that was in one of the packages. Enjoy.
Jamie
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
I have a set of NIP 2572 fronts and 2573 rears that are available if someone wants a completed NIP set. See them in BST forum.
This is all very interesting!
Return to “Identifications”
