Ayk resto Project
- Dr. Robotnik
Re: Ayk resto Project
Excellent work. But can you tell me a bit more about how you've fixed up the lexan body. e.g. what materials and methods have been used, etc. Thanks in advance.
as far as body repairs go, I have tried to save this old shell. The only option is to paint on top and repair the damage. Which mostly consists of holes done by the previous owner , so i cut out the windows becuse i will be doing a black netting material , anyway i used the lexan from the windows as patchs for the under5side, sanded the area to be glued on with 120 grit , then i cut them accordingly and jb welded them under the holes also kinda filling the holes on top, once dry 2 part autobody puddy was used to smooth over the low spots on top then 220 grit dry paper the whole thing and degreased then 2 light coats of this tamiya primer. I must say this is the frist time using tamiya primer i wanted to use a light primer so it doesn't fill in the little body lines like the usual autobody primer i use. i will sand it down then prime it again then sand it .I figure it should be ready for paint i will probley finish it off in 600 wet grit as a final.
- Attachments
- DSC06517.JPG (146.63 KiB) Viewed 476 times
- DSC06526.JPG (144.11 KiB) Viewed 476 times
- DSC06519.JPG (142.93 KiB) Viewed 475 times
- DSC06520.JPG (154.98 KiB) Viewed 475 times
- 4305 Views
- 30 Replies
- 3336 Views
Last post by Bormac
- 1810 Views
Last post by GJW
- 23 Replies
- 4677 Views
Last post by DennisM
- 1388 Views
Last post by Ayk Viper
- 28 Replies
- 4933 Views
Last post by stickboy007
- 1434 Views
Last post by shoman24v
- 1092 Views
Last post by hawgfanman
