The Ugly Truckling JRXT
Has thanked: 268 times
Been thanked: 2094 times
Re: The Ugly Truckling JRXT
The short tires will help some, but I wouldn't bash a stadium truck with a 14T motor. I'll give up some speed for run time and reliability.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
I decided to plastic weld the crack in the steering arm and carefully adjusted the end points to avoid stress on it.
Onyx motor.
-Brad
BattleTrak
A few minutes into the run with the Onyx motor, it threw out a rear outer hinge pin. The snap-in clips that I used were worn and iffy, so not too shocked. Upgraded both sides with 5-link A-2007 pins and some used spacers.
Then had a nice run with it for about 15 minutes until the motor got a little too warm. It ran great though…25+mph on the road and just floated over the grass in the yard.
-Brad
If they are 1/8" hinge pins, Custom Works E clips work good and are cheap.
If the grooves of the pins are worn, maybe use a 3mm E clip. I've had to do that with several RC10's.
BattleTrak
I have been having a blast driving this truck! After a wicked high-speed cartwheel that chucked a tie-rod and a few near misses with fence poles…I installed this used JG on-road bumper to the truck. It totally fits and will help protect the front bulkhead & suspension better. It has been surprising how well this truck and the 30 year old parts are holding up to abuse.
-Brad
RogueIV
Has thanked: 2133 times
Been thanked: 1099 times
Post by RogueIV »
The old losi stuff seems to hold up really well. I actually contemplating running my LXT during a Trophy race, because why not?
mikesofunny
Has thanked: 194 times
Been thanked: 48 times
Post by mikesofunny »
I LOVE the idea of using the "not shelf quality" stuff to build a runner! The last time I had a bunch of spare Losi parts laying around I ended up doing a full resto-mod LXT. Excellent work sir.
BattleTrak
I have been driving this truck a lot and decided to make it not quite so ugly with a body upgrade.
Shake and Bake!
-Brad
RogueIV
Post by RogueIV »
BattleTrak wrote: Sat May 06, 2023 11:15 pm I have been driving this truck a lot and decided to make it not quite so ugly with a body upgrade.
Shake and Bake!
wonderful!
Return to “Losi Forum”
