Confirmation if a Le Mans 240SB armature is authentic?
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Re: Confirmation if a Le Mans 240SB armature is authentic?
To clean the comm superfast just chuck the pinion side into a cordless drill, while its spinning hold #0000 steel wool on the comm...it will look new in seconds
OMG that was so kind of you to take apart your SPA !
I recently received from the bay a 240 combo. The ST is definitely correct but i don't believe the WS is
Would you by chance please post some picks of your 240ws innards? I firet searched several days with google/images and used a vpn to spoof several countries to get different results but could not find one.
(I knew I should have bought that 240ws armature this past winter when i saw it on the bay. So Full of REgerts<-tattoo
- Been thanked: 325 times
Wow, over $13 for that? Just get a bit of fine-grit sandpaper, 1000 grit or higher, a few twists and call 'r done. Works great for slot car pickup shoes, too.Frankentruck wrote: ↑Thu Apr 07, 2022 10:11 pm You guys have some really dirty commutators there. Juicedcoupe shared this comm cleaning stick link a while back.
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2979 times
It has gone up with a nearly 50% price increase since that was posted.
Those unnecessary and overpriced niche products targeting hobbyists make me laugh sometimes.
It reminds me of another product, specialty "bearing washers". Get a small plastic cream cheese container, some WD40, insert bearings, and give it a good shake. Done. It is to laugh!
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
That one is the same thing as Trinity used to sell. But any fiberglass scratch pen works.
I have a comm lathe and different grades of comm sticks, but I still use the fiberglass pens. They are really helpful for cleanup after cutting the comm.
- R6cowboy
- Has thanked: 871 times
- Been thanked: 903 times
Sure thing, not a problem. That's certainly not a 240WS armature, it's a 27T singe unit. They came in a bunch of different stock motors. The 240WS is a 18T double with 0.65mm wire. I'll get back to ya soon on that.Nefarious wrote: ↑Wed Oct 04, 2023 12:24 am OMG that was so kind of you to take apart your SPA !
I recently received from the bay a 240 combo. The ST is definitely correct but i don't believe the WS is, its a single wind. It looks like something I have seen before but I can't remember when, where or what in.
(I knew I should have bought that 240ws armature this past winter when i saw it on the bay. So Full of REgerts<-tattoo)
-Jerry-
- 19 Replies
- 3098 Views
Last post by mjtown
- 1812 Views
Last post by howsyouraspen
- 1067 Views
- 1913 Views
Last post by mamadoesntletme
- 1684 Views
- 516 Views
- 436 Views
Last post by Toyotachris1982
- 1216 Views
Last post by RC10th
Users browsing this forum: DotNetDotCom.org [Bot] and 2 guests
