Newbie with Race Motor and AE RC10
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Re: Newbie with Race Motor and AE RC10
JT
Look for bearings at https://www.avidrc.com/flexkit/?kit=680&kitname=RC10+Classic.
$1 per bearing. You will be stunned by the price some are asking for vintage AE bearings.
BITD they were quite expensive but no longer.
Chuck
Chuck
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
I couldn't agree more, Chuck. I won't waste money on vintage AE bearings.radioactivity wrote: ↑Mon Oct 21, 2019 11:06 am JT
Chuck
For playing around in the yard, bearings are all the same so may as well go for the cheapest option - Avid bearings are just fine.
- XLR8
I no longer run my vintage ESCs but I do know that low-voltage alarms are available for those who do.JTSpeedDemon wrote: ↑Mon Oct 21, 2019 10:28 am I'd think it would be a good idea to install a small voltmeter. Or maybe some kind of low voltage cutoff? Or is there some kind of protection components I could install? I know how to solder and have adequate equipment.
I checked, and it's two separate heat sinks, I was able to remove the small one entirely and reinstall it.
Would it be a problem to switch to Li-ion or another kind of battery chemistry?(As long as it's in the voltage range of the motor of course)
Here's one from Amain hobbies:
https://www.amainhobbies.com/dys-digital-lipo-voltage-checker-w-warning-alarm-budepb-0002/p360824
There may be better/cheaper ones out there.
As for Li-ion, I've only ran NiCad, NiMh, and LiPo batteries so I can't say if other battery types would be safe to try.
- JTSpeedDemon
- Has thanked: 25 times
Ok, then I'll probably go with NiMH.
Is there a way to retrofit it with a tempfet or a similar device? Some kind of high temp cutoff?
Original Cadillac A stamp AE RC10 with Hot Trick parts! That's how I roll!
not that esc. But you could really find esc's out there relatively cheaply that will have a lipo cutoff built in as well as thermal and overload circuitry.
such as this one:
https://www.amazon.com/HobbyWing-QUICRUN-1060-Brushed-ESC/dp/B00LXCM3Q8/ref=asc_df_B00LXCM3Q8/?tag=hyprod-20&linkCode=df0&hvadid=309875687217&hvpos=1o2&hvnetw=g&hvrand=13407414182468964595&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9007247&hvtargid=pla-568634278734&psc=1
such as this one:
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
Bearings purchase from Avid also I’ll suggest buying a super cheap brushless esc/motor combo from eBay for you to get your feet wet with the new stuff. It’s so cheap it won’t matter if you burn them up
- JTSpeedDemon
Link to said combo? Would probably be a good idea for everyday thrashing, but I see so many on Ebay that look like junk.
- JTSpeedDemon
Finally went and got a 7.2V NiMH 5000 Mah battery, a trickle charger for it, and a Tamiya male to female adapter(all on Ebay for less than $30!!!). I can splice and solder the needed male half of the adapter to the existing battery wires, charge up the battery, plug it in and rip! I'll link a video of me getting it running once everything comes. Can't wait to see this thing run again!
- radioactivity
- JTSpeedDemon
I think I found one of the Ebay special brushless motor kits y'all were talking about. HOLY MAKER OF RC!!!!!
9T motor, up to 12V, 50,000 max RPM!!!! https://www.ebay.com/itm/For-1-10-RC-Car-3650-3900KV-Brushless-Waterproof-Motor-with-60A-ESC-Combo-Set/264384136903?hash=item3d8e85c6c7:m:mHGSvQhQa986ebVfkH1nHAw
I think that would absolutely TRASH my diff.
Maybe someday I'll get a project car to put one of these in......
- KidAgain
- Business Member
youll be fine, see you could get them for under 40$ package deal.....................................JTSpeedDemon wrote: ↑Mon Oct 21, 2019 6:22 pm I think I found one of the Ebay special brushless motor kits y'all were talking about. HOLY MAKER OF RC!!!!!![]()
I think that would absolutely TRASH my diff.![]()
Maybe someday I'll get a project car to put one of these in......![]()
- JTSpeedDemon
Really? The stock rear end could handle that? And by what safety margin?
If it's not dangerous or risky component wise, it's be fun to make the electronics swappable for quick changes.
Plus I've got a friend with a gas(might be nitro) RC, and it might be fun to race it with that brushless setup at max 12V!
- XLR8
I think one of the weak links in the RC10's original 6-gear tranny are the white nylon idler gears. I've broken two idlers running with 10.5 brushless on 2s lipo (7.4v). I'm running the later black idlers now and they seem to be holding up okay - plus I've adjusted my driving style a bit.
The lesson for me is that these cars are not indestructible, they were designed in an era when running modified meant 7-cell NiCad (8.4v) and maybe a 12t brushed motor. 3s lipos and brushless motors can make tremendous power - much more power than these old cars can handle.
- KidAgain
- Business Member
Sorry about that I’m running stealth trans and those seem to hold up fine so far with a 4.5 brushless, 6 gear not sure.
- JTSpeedDemon
Lol, yeah, aftermarket diff probably helps.
I got a question for you guys: What are the stock tire sizes for this AE RC10?
The rear wheel is 1 3/4" in dia. and the rear tire is ~3"dia. and 1.5" wide.
The front wheel is about 2" in dia. and the tire is 3" in dia. and 1/2" wide.
Any tire and wheel suggestions? On road would be nice, but I'd also like to see some other off road tires.
I saw the JC Racing link, but I'm not sure if those will fit the same size tires.
- 1357 Views
Last post by Toasted Coastie
- 20 Replies
- 5758 Views
Last post by R Cane
- 3155 Views
Last post by juicedcoupe
- 1832 Views
Last post by a01butal
- 821 Views
Last post by THEYTOOKMYTHUMB
- 1195 Views
Last post by jooles
- 845 Views
- 1565 Views
Last post by TOLITS
Users browsing this forum: DotNetDotCom.org [Bot] and 2 guests
