Can you count the number of teeth on each shaft? I'm surprised you ran into problems with this, because it worked for me.K Rob wrote: ↑Thu Jan 20, 2022 8:51 am IMG_20220124_182825241.jpg
No, I don't mean the lengths.
I mean the diameter of the section of shaft with teeth on it.
Unfortunately I don't have the Rampage shaft to hand as it's with a chap making a motor plate for me to show a comparison, but it is bigger in diameter than the Pro X version.
So the Pro X version does not give a good connection to the diff gear when it's in the Rampage box.
There is too much backlash between the gears using the Pro X shaft.
Kyosho SST transmission diagnosis
- stickboy007
- Been thanked: 55 times
Re: Kyosho SST transmission diagnosis
- K Rob
- Been thanked: 5 times
They both work in the Rampage box (once shimmed of course) but there is definitely more backlash in the mesh between top shaft and diff gear with the Pro X shaft.
I got my hands on the shafts to compare sizes, but stupidly didn't actually count the teeth before I gave it back to the guy doing the motor plate.
I did measure them though and with the calipers placed onto the same teeth profile for each shaft, the Rampage gear is 0.7mm bigger.
It's not much but with the price of Rampage diff gears I wasn't prepared to risk it.
CML Distribution - FTX - Etronix - Fastrax - Centro
RC Racer Magazine
RC Racer Magazine
- R6cowboy
- Has thanked: 871 times
- Been thanked: 903 times
I'm currently rebuilding the Pro XRT I picked up last year. I didn't check the SST trans before disassembling it, but when I reassembled it according to the manual, it's buttery smooth as can be. Must have gotten lucky and got one of those later "corrected" trans cases.
-Jerry-
- 2022 Views
Last post by aip47-2008
- 293 Views
Last post by Dangeruss
- 1244 Views
Last post by njdriver04
- 207 Views
- 19 Replies
- 2925 Views
Last post by losiXXXman
- 349 Views
- 3595 Views
Last post by DerbyDan
- 178 Views
Last post by Scottzone
