gold pan A&L mid motor conversion
Has thanked: 1075 times
Been thanked: 3680 times
Re: gold pan A&L mid motor conversion
Those look like Lunsford to me 8)
Factory Works website
vandal
Post by vandal »
yep gomachv they are indeed lunsford :) stealth case screws had to grind 2 of em a tad shorter not to hit slipper back tho! V
ps thx for the kind words :)
NomadRacer
Has thanked: 81 times
Been thanked: 78 times
Post by NomadRacer »
:shock: Never knew they existed!
Edit:
Do you guys happened to have a part number for the screws? I don't see them on the Lunsford webstore :?
Bum on Direct Deposit
vandal
Post by vandal »
you want to contact Barb via the website, she can set you up. They are literally made to order, and hand rolled threads. He was making a batch for Stewart Haas last time I was there :shock:
vandal
Post by vandal »
gotta watch yer fingers on that machine eh? lol fun to do !
Yeah, its a beast. Im sure fingers have been rolled before in one of those
NomadRacer
vandal wrote: Sun Dec 17, 2017 3:00 pm umm there out of my stash from bitd... he may not make em anymore :(
edit:
http://www.lunsfordracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LUNS&Product_Code=A4B1125&Category_Code=STDBUTTON
:) V
Thanks for the link, have to get some.
vandal
Post by vandal »
heyo mini update! got some free time and dyed my white parts :) found some 30 year old rit dye in the shop (leftover from when i dyed my 2nd rc-10) and it was still liquid lol as u can see it worked awesome!
more to come as i get time to work on it :)
NomadRacer
Black Out 8)
Do you have any tips on drilling/slotting the tub for the trailing arm mount plates? That step is coming up for me real soon... https://www.rc10talk.com/viewtopic.php?f=36&t=42537 I've never done that modification!
On the two that I did, I found it was easiest to drill from the inside with a tiny bit, as close to the bottom corner as you can. Then make the slot bigger from the outside. You want it as close to the flat part of the chassis as you can, and only 3/32 or so tall, so small bits are best. Just remember you can’t put the material back, so take small amounts at a time.
I bet someone that is really creative could make a jig that holds the Dremel steady against the chassis to cut a straight line
NomadRacer
Small carbide bits I have, plenty of them! Iv'e sorta got a plan to do it but was looking for any top secret methods. :D
vandal
Post by vandal »
i used the same technique as gomachv got it close then used a small file to get the final size..
vandal
Post by vandal »
ok final build update! finished up finally was a fun build :) special thanks to factory works, and conklin design and of course lunsford racing ! had to limit the down travel of shocks to keep dogbones from rubbin on outdrives and re- cycled a really old body until i can score a new body :) used some vintage electronics and batteries (when i can swing it they will be replaced with brushless and lipo) for a radio i stole a 2.4 receiver and radio from a losi rtr i bought several years ago:) ok heres the pics :) thx for reading and looking ! :)
Looks great! You don’t see mid motor trailing arm cars much! Not since the MRP pro 10 anyway!
Users browsing this forum: No User Avatarmikea96 and 3 guests
