just bought a rc10b2 new built
hugger19
Has thanked: 25 times
Been thanked: 143 times
Re: just bought a rc10b2 new built
Post by hugger19 »
k thanks. this car has the 3 hole rear arms since it is a new built buggy so i would say its a "TRUE" B2 buggy. will post up some pics of the body going to add a couple correct stickers. i know its not the same body as matts car, but the paint job is close and very well done.
hugger19
Post by hugger19 »
just found these on ebay 2 hole and 3 hole both b2's.
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
Staple removed or incorrect packaging, it looks like the staple was removed and parts changed.
i remember seeing this oddity before too, 2 hole vs 3 hole on a B2. somewhere on this forum.
transamman908
Post by transamman908 »
My new built b2 built from kit form has 2 hole rear arms. I've also seen other new in pack b2 arms vary from 2 hole to 3 hole over the years.
slotcarrod
I will check my un built kit when I get home and also my un opened spares and let you guys know.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Post by DennisM »
I´ve got both 2 and 3 hole versions NIP with the same part number.
But also a couple of sets with two different part numbers.
Gone fishing
hugger19
Post by hugger19 »
now as far as RARE parts go for these cars (since i hear that alot when it comes to these cars) minus the super rare pre production parts(trans mount & no hole rear chassis plate), which are the rare hard to find parts for these cars???
so far from what i have read:
1. the front wheels
2. the no sway bar hole front top plate
3. white steering bell cranks
any other parts????
R Cane
Has thanked: 159 times
Been thanked: 64 times
Post by R Cane »
original kit rear tires
front bumper is fairly rare
transamman908
The 9240 chassis plate is not easy to come by. 9200 standard chassis is pricey now when found. If duplicating the manual as far as electronics then the Reedy cells, LRP Esc and the Airtronics 94155 is a challenge to locate.
slotcarrod
The correct chassis with no holes for the rear sway bar is very rare and often overlooked. The part number continued on the newer version with holes.
hugger19
Post by hugger19 »
adjusted some stickers around and added a couple lrp ones :)
yellowdatsun
Post by yellowdatsun »
What is that big hump under the window of the body for? I could see a small hump like on the re-re RC10 body, and my B3 lid has a little hump, but the one on that B2 is HUGE.
R Cane
Post by R Cane »
The B2 came in two virgins, the Sport and Racer...that body is for the Sport, which was boxed with a mechanical speed control. The Racer was ESC, and had the much smaller bump.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
R Cane wrote:The B2 came in two virgins
Lucky B2!
Users browsing this forum: No User AvatarAhrefs [Bot] and 7 guests
