JRX Pro SE Rebuild
Re: JRX Pro SE Rebuild - Questions
Dans is a really nice build indeed.
Could someone enlighten me on th e RPM rear h arm conversions I have? I presume they convert a Pro from 5 link to the standard of a Pro SE? I have never taken them out of the packet and don't really want to open it if I don't need to.
Does anyone have the TBG 'aftermarket' body on thier Pro SE? I would like to see one painted and compared to a normal one.
I am not affiliated with oldrc.com, I'm just old when it comes to my RC history
- DerbyDan
- Been thanked: 19 times
The original short wheel base JRX2 was the only Losi buggy to have the 5-link suspension... the JRXPro, The Junior 2 both came with the more regular H-Arm set-up but had the provision to fit the trailing arms for the 5-link.... the Pro SE (which you say yours is) had the moulded chassis (like the Junior 2 has) but didn't have the holes/provision to fit the 5-link trailing arms.
I'm unsure if the RPM H-Arm kit was a set of parts that was released before Losi made their own H-Arm option parts (which incidentally was available before the Pro kit was released & formed part of a LWB upgrade kit for the JRX2 called the 'Performance Kit') Or if the RPM items were just sold alongside the Losi items, marketed as being stronger?
- DerbyDan
... Oh & I forgot to mention, the two-tone blue & white shell on my JRX2 runner is a TBG shell - & its a very good reproduction (lines are crisp & lexan clear & bubble free), its a little smaller O/A compared to an original, but all is OK with some care cutting it out. So I don't see why there would be any reason why their ProSE shell would be any different?
The RPM items are a 'conversion' so I would hazard a guess they were released after the Pro SE was released, to change 5 link to the newly released h-arm on the SE.DerbyDan wrote:The original short wheel base JRX2 was the only Losi buggy to have the 5-link suspension... the JRXPro, The Junior 2 both came with the more regular H-Arm set-up but had the provision to fit the trailing arms for the 5-link.... the Pro SE (which you say yours is) had the moulded chassis (like the Junior 2 has) but didn't have the holes/provision to fit the 5-link trailing arms.
Mine is for sure a Pro SE, raced in for years, it has the moulded chassis.
Sounds good enough, I think I will get one of each style they do, thanks.DerbyDan wrote:... Oh & I forgot to mention, the two-tone blue & white shell on my JRX2 runner is a TBG shell - & its a very good reproduction (lines are crisp & lexan clear & bubble free), its a little smaller O/A compared to an original, but all is OK with some care cutting it out. So I don't see why there would be any reason why their ProSE shell would be any different?
I'm literally building a new car out of new bits, going to cost me a fortune!
Just to confirm, the retrofit tranny casing is a light grey colour as opposed to the dark grey/black colour of the original?
- Has thanked: 1129 times
- Been thanked: 3919 times
- LosiXXkid
Yup! Just don't keep score though.....it can be scary!oldrc wrote:Sounds good enough, I think I will get one of each style they do, thanks.DerbyDan wrote:... Oh & I forgot to mention, the two-tone blue & white shell on my JRX2 runner is a TBG shell - & its a very good reproduction (lines are crisp & lexan clear & bubble free), its a little smaller O/A compared to an original, but all is OK with some care cutting it out. So I don't see why there would be any reason why their ProSE shell would be any different?
- LosiXXkid
All the ones I've seen have been light grey.oldrc wrote:Just to confirm, the retrofit tranny casing is a light grey colour as opposed to the dark grey/black colour of the original?
- DerbyDan
[/quote]The RPM items are a 'conversion' so I would hazard a guess they were released after the Pro SE was released, to change 5 link to the newly released h-arm on the SE.
Mine is for sure a Pro SE, raced in for years, it has the moulded chassis.[/quote]
The ProSE was H-arm as standard - the chassis wouldn't even accept the 5-link set-up from the JRX2 - if this kit was a conversion to 'H' Arm, then I would suggest that it pre-dates the JRXPro SE
I thought that initially, but that would mean RPM came up with it first and Losi copied them and put it on the SE as standard. But logically I would say that the SE came out and RPM did the conversion so that people could get the h-arm without having to buy an SEDerbyDan wrote: The ProSE was H-arm as standard - the chassis wouldn't even accept the 5-link set-up from the JRX2 - if this kit was a conversion to 'H' Arm, then I would suggest that it pre-dates the JRXPro SE
But I could be wrong which is likely
Thanks that's what I thought.LosiXXkid wrote:All the ones I've seen have been light grey.oldrc wrote:Just to confirm, the retrofit tranny casing is a light grey colour as opposed to the dark grey/black colour of the original?
Yet another question, is there a part number for a complete screw kit?
Thanks
Thanks
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
Dan is right. The ProSE is Losis fourth buggy, the JRXPro and Junior2 came between the two and all of them had H arm suspension. The JRX2 was the only one with the five link. You can confirm this by looking at the manuals at http://www.vintagelosi.com/Buggies.htmloldrc wrote:I thought that initially, but that would mean RPM came up with it first and Losi copied them and put it on the SE as standard. But logically I would say that the SE came out and RPM did the conversion so that people could get the h-arm without having to buy an SEDerbyDan wrote: The ProSE was H-arm as standard - the chassis wouldn't even accept the 5-link set-up from the JRX2 - if this kit was a conversion to 'H' Arm, then I would suggest that it pre-dates the JRXPro SE
For screws you are going to have to go through the Pro manual http://www.vintagelosi.com/Manuals_files/jrxpro.pdf and SE supplement http://www.vintagelosi.com/Manuals_files/jrxprose.pdf and make up your own list. For US size screws I personally use http://modelfixings.co.uk as you can order individual screws if you want and they always seem to have everything in stock.
- Synergy
- Has thanked: 127 times
- Been thanked: 72 times
If you check out my gallery......oldrc wrote:I thought that initially, but that would mean RPM came up with it first and Losi copied them and put it on the SE as standard. But logically I would say that the SE came out and RPM did the conversion so that people could get the h-arm without having to buy an SEDerbyDan wrote: The ProSE was H-arm as standard - the chassis wouldn't even accept the 5-link set-up from the JRX2 - if this kit was a conversion to 'H' Arm, then I would suggest that it pre-dates the JRXPro SE
http://www.rc10talk.com/viewtopic.php?f=77&t=18939&start=0
.......from about post 6 there are a few entries that might help clear this up
My feeling is (and I could be wrong) RPM developed the H arm conversion pre the release of the JRX Pro.
Here's my TC Showroom
- 41 Replies
- 9407 Views
- 1191 Views
Last post by GJW
- 20 Replies
- 4190 Views
Last post by JustX
- 2893 Views
Last post by RogueIV
- 1509 Views
Last post by cas22
- 1672 Views
Last post by Momo5
- 1850 Views
Last post by Bongo Fury
- 3922 Views
Last post by RCveteran
