SFC K's Re-Re build
- Has thanked: 100 times
- Been thanked: 205 times
Re: SFC K's Re-Re build
You know, this comment about shock spacers has made me think. This Re Release and something like a Tamiya Re Release are in two completely different leagues. Something like a Tamiya you build by the book and run it or shelf it box stock... This is a 'race car' and rarely are these ever box stock, generally being built looking half at the manual half at the pile of clippings from rc car action and even a little bit at that little black book of secrets trying to make your RC10 faster and handle better then the next guys RC10. The manual was more of a guide then a bible... That is why these were so versatile, you didn't build them.. you created your own special version of them.
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
gomachv wrote:Well that's gonna be a problem, they need to fix that. You'll want to go back and get three of those in there or a 5/8 spacer of some sort. Original was fuel tubing. Without it, you'll lose and chew up dogbones
Well that sucks, now that they are full of oil....
Jeff
- Has thanked: 1129 times
- Been thanked: 3919 times
Yes and it helped a guy like me who would have ended up in the same boat. I have plenty of nitro fuel tubing laying around, should I just go with some of that under the piston?gomachv wrote:Yes but better now than after you chew up stuff!
-Joe
Pour the oil back into the container, it's not like it's used oil
Chris
Chris
- SFC K
joeman37 wrote:Yes and it helped a guy like me who would have ended up in the same boat. I have plenty of nitro fuel tubing laying around, should I just go with some of that under the piston?gomachv wrote:Yes but better now than after you chew up stuff!
-Joe
That is what I plan on doing. I'm not going to buy something that should have been in the box. They will both do the same thing...
Jeff
- Has thanked: 36 times
- Been thanked: 1318 times
Yep, the manual has an error here. The original manual told you to use a 5/8" long silicone fuel tubing as a spacer, and subsequent manuals had different spacers and shaft lengths.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
I would recommend not to use fuel tubing, as under harsh condition, that fuel tubing will simply crunch and make a mess as well. I woudl use AE ad hoc shock spacers, they are always useful to have at hand. And indeed, I would always attach the bottom of rear shocks to the outer hole and only move the holes on teh shock tower to make adjustments, I've always wondered why there was 3 other holes in teh rear arms, I never ever used these! At rest and fully loaded, arms should be more or less parallel to the ground and when lifted only a tad lower but not much (10-15° maybe) !
Come and visit the stable
- SFC K
Thanks for the advice, but I have used fuel tubing in a lot of shocks internal and outer and have not had issues.
Are you referring to the shock down stops, Part number #6466 like previously mentioned?
Jeff
Yes, I believe He isSFC K wrote:Thanks for the advice, but I have used fuel tubing in a lot of shocks internal and outer and have not had issues.
Morten Max
How is the fuel tubing going to crunch? The tubing comes under pressure when the shock is not under load. If it was taking a beating when the shock would go under load I could see some concern but this is just limiting unloaded travel and you are not stressing the tubing much at all. I am going to go with it and see how it works.Asso_man! wrote:I would recommend not to use fuel tubing, as under harsh condition, that fuel tubing will simply crunch and make a mess as well. I woudl use AE ad hoc shock spacers, they are always useful to have at hand. And indeed, I would always attach the bottom of rear shocks to the outer hole and only move the holes on teh shock tower to make adjustments, I've always wondered why there was 3 other holes in teh rear arms, I never ever used these! At rest and fully loaded, arms should be more or less parallel to the ground and when lifted only a tad lower but not much (10-15° maybe) !
-Joe
It was good enough for the early cars, good enough for me. I kind of like the idea of a bit of cushion, instead of three spacers I would always use two and an oring back in the day.
- 2259 Views
Last post by SFC K
- 23 Replies
- 3339 Views
Last post by Diggley
- 582 Views
Last post by mk-Zero
- 1695 Views
Last post by SFC K
- 1272 Views
Last post by Hcp22
- 1525 Views
Last post by THUNDERSTRIKE1
- 937 Views
Last post by Hcp22
- 2077 Views
Last post by SFC K
