Gear Cover
- Has thanked: 35 times
- Been thanked: 10 times
Re: Gear Cover
Hi,
perhaps a stupid question, but I see you're useing the TRIAD slipper right? I've tried that also, but the inner part of the slipper binds against the trans case because there's no "stop" on the b4 topshaft. What am I missing here?
my car is a T3 with the ASC9601Team Associated Top Shaft (B4/T4).
tnx
Bastian
tnx
Bastian
- DMAT
- Been thanked: 4 times
Re: Gear Cover
I'm actually a bit curious on the triad slipper too.
hows thats working for you and what mods did you need to do it.
I doubt ill get around to trying it myself for a while but I know it says its compatible with the b4.1 but not b4, I would check out the assembly guide for the two and see what differs. Maybe you just need to add a spacer to it?
Re: Gear Cover
I added a few spacers to get it aligned properly with the motorplate, but that doesnt't fix the "binding isue".
I guess the asso. inner slipper disc has some kind of flange to keep it from binding against the trans case..??
hope anyone can help cos this is frustrating!
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Gear Cover
Drill the topshaft hole in the case larger and cut a spacer to go from the bearing to the inner triad hub.
Re: Gear Cover
Re: Gear Cover
the spacer should only touch the inner race, just like on the topshaft gear side. that's not gonna destroy a bearing. there isn't much (if any) pressure on the bearing anyway.
the b4 spacer is probably too long which is why i said "cut" one. i got k&s aluminum tubing at the lhs to make mine.
- trek
Re: Gear Cover
I did purchase a spacer, If I remember correctly it was the B4 spacer. On my buggy I have a MIP topshaft that is a bit different and doesn't need as large of a spacer (you do have to change the bearing on the slipper side to run the MIP topshaft). The spacers that came with the Avid gear were all I needed on that. I think on the 3rd one I found an old bushing from an RC10 that worked great. And yes you have to drill a bigger hole in your case.
The slipper seems to work well, but I haven't used any other B4 type slipper, so I can't compare it to those. I have one RC10T that is running the original slipper and the Avid seems to have way more holding power. I've been racing an RC10 and RC10T every week since Nov/Dec and I have yet to have to make an adjustment after I did the initial settings. I don't know if that is normal or not....
Re: Gear Cover
It aluminum not stainless.it mite be clear ano on it.you mite want to try mothers polish or even 1000 grite sand paper then try the polish but it will shine if you work it enough.DMAT wrote:just a few more notes. It doesnt have very much clearance for a thick slipper. I dont think anything beyond the basic b4 slipper will fit. The 6 gear and stealth ones do fit but there is very little free room.
another note is im not sure which metal its using. my aluminum polish has no effect so maybe stainless steel. It has the machined look to it but i cant get it to polish. I'll have to try sand paper or something other than a polishing cream on it.
My pop always said i had to many iron's in the fire
- 571 Views
Last post by dinglem
- 954 Views
Last post by harvey
- 657 Views
Last post by rctenracer
- 427 Views
Last post by a01butal
- 1288 Views
- 1442 Views
Last post by markbt73
- 2008 Views
Last post by cautrell05
- 930 Views
Last post by RC Chick
