Gear cover compatibility?
- markbt73
I'm bringing an RC10CE Stealth back to life, and I'm missing the pinion/spur gear cover. I did a quick search on Tower's website, but I didn't find either the stock one or the RPM replacement. Are they still available anywhere? If not, is the cover from the B4/T4 (which are a dime a dozen) compatible? Do any other covers fit?
My new pinion and spur gear thank you in advance.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: Gear cover compatibility?
Repro gear covers are available on eBay from teambluegroove.
http://www.ebay.com/sch/teambluegroove/m.html?_nkw=rc10+gear+cover&_sacat=0&_odkw=gear+cover&_osacat=0&_trksid=p3911.c0.m270.l1313
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
B4 ones fit well, and are twice as durable plus- work with the V2 slipper shaft
- RC104ever
Second the B4 covers. I use one. Only thing is that you can only use the top screw OR you have to drill a hole to use the bottom one.
- Chris
Lots of cars...so many cars
- markbt73
Thanks. If the B4 cover can be made to fit, I'll just use that, since they're available locally.
- 923 Views
Last post by RC Chick
- 449 Views
Last post by zoomzoombang
- 568 Views
Last post by dinglem
- 953 Views
Last post by harvey
- 655 Views
Last post by rctenracer
- 23 Replies
- 2723 Views
Last post by chophead69
- 902 Views
Last post by slapshot1979
- 426 Views
Last post by a01butal
