I need some help identifying which mid I have
- Has thanked: 5 times
Re: I need some help identifying which mid I have
To be honest, I got it because Optimas were the biggest, baddest thing ever when I was a teenager, but they were made of unobtanium as far as my wallet was concerned. I still really want an optima or javelin, but I think this will be just as fun for a mild track day once in a while
- Been thanked: 325 times
I'd agree that your Mid would be worthy of restoring and even driving. It was and still is a beautiful piece of engineering and an excellent-driving car.perry wrote:wow! thanks guys.
so apparently I have a standard optima mid that's had a few pieces and parts changed around.
I had it up for sale, because i didn't think I'd be able to run it and find parts(and i have too many r/c projects already), but it looks like i'm gonna keep it and find some spare belts for it.
oh, and it doesn't have the one way diff in the front.
thanks, after seeing some of your builds (and some others on here) I can honestly say I'm a little out of my league here, but I don't want to restore, more along the lines of a resto-mod.Coelacanth wrote:I'd agree that your Mid would be worthy of restoring and even driving. It was and still is a beautiful piece of engineering and an excellent-driving car.perry wrote:wow! thanks guys.
are there any modern cars that have interchangeable parts that you guys know of? like shock towers, or bellcrank steering? I really don't like the idea of single shear elevated bellcranks on a carbon chassis, that is pretty much irreplaceable.
for that matter, are there any suppliers for older kyosho parts still? I've bought from sabula tech for my Losi, but he doesn't carry much for the kyosho.
Thanks, resto-modding is my idea of fun and for me, more challenging than just following instructions and building something by the manual.perry wrote:thanks, after seeing some of your builds (and some others on here) I can honestly say I'm a little out of my league here, but I don't want to restore, more along the lines of a resto-mod.Coelacanth wrote:I'd agree that your Mid would be worthy of restoring and even driving. It was and still is a beautiful piece of engineering and an excellent-driving car.perry wrote:wow! thanks guys.
You should have a closer look at my OptiMutt project, a lot of what you're looking for is right there.are there any modern cars that have interchangeable parts that you guys know of? like shock towers, or bellcrank steering? I really don't like the idea of single shear elevated bellcranks on a carbon chassis, that is pretty much irreplaceable.
I forgot about the arms and carriers in that thread.
I don't think the bellcrank will work while keeping 4wd though, unless I can get enough swing in there without hitting the belt and mounting flat aluminum bar center link on top, essentially reversing your center link/tie rod set up.
Whats this mystery project you speak of, you really have me curious!keithrc wrote: That said, I made up an alloy copy of the small FRP plate (without the MSC mounts) for my "mystery Turbo Mid" project that I'm planning.
Keith
- keithrc
- Has thanked: 20 times
- Been thanked: 15 times
It wouldn't be a mystery if I told you would it?
All will be reaveled in the near future.
Keith
Keith
NIB Optima!
NIB Turbo Optima
My threads:
Optima's http://www.rc10talk.com/viewtopic.php?f=30&t=29477
Mids http://www.rc10talk.com/viewtopic.php?f=30&t=29489
Lazer's http://www.rc10talk.com/viewtopic.php?f=30&t=29525
NIB Turbo Optima
My threads:
Fair enough
I have a couple other mid projects in the works too
- j0pp3
- Been thanked: 4 times
Me too... can't have too many Mid projects
Cheers
Joel
Joel
Even though I have four Lazers (at present count) I have a soft spot for the Mids, current count is seven (not all built but the parts are here) who knows where it will end up though
I'm pretty sure it could be done with a few spacers with the right thickness and maybe changing the orientation of the L-arms. I found with this unit, you could mount it several ways; I chose to keep the center-link underneath, I just added enough aluminum spacers to get the turnbuckle/ball ends to clear the bottom deck, especially where it has that slight up-turn on the sides. The A & L crank was also used with the Mids, I believe, and it's pretty much the same thing--only using Day-Glo yellow nylon instead of aluminum. I even had a close look at an alloy RC10 bellcrank but tossed that idea out the window because I didn't want to have a mix of Metric and Standard screws on the car.perry wrote:I forgot about the arms and carriers in that thread.![]()
well, I hate to do it, but I think I'm going to sell. I had a guy contact me on rctech from the ad i put up on there when i was going to sell. I'll see what he has to offer.
I just can't put the time or money into it right now, and I already have my Losi JrxPro SE I've been holding onto. Plus, I really want an original Optima. If I had that, it would be no question about holding onto it. I have 9 cars right now, and need to thin down.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Thinning is not an option - kind of like retreat
But You should get Yourself an Optima, I´ll support that idea
Gone fishing
well, it turns out that I sold it to Wydraz
I am going to focus on my Losi project, then I'll be back to searching out an Optima, probably piece by piece.
- 52 Replies
- 13540 Views
Last post by HKS_TRD
- 1955 Views
- 1319 Views
Last post by sgirouard
- 752 Views
Last post by Falsepleasure
- 986 Views
- 1082 Views
Last post by fieldbaja
- 638 Views
Last post by mrlexan
- 1805 Views
Last post by _timmy_
