I was thinking the the same thing reading this thread....talk about availability of some different options to try.cautrell05 wrote:...in the last 3 months i have picked up 32 pairs of mounted buggy tires for about 90 bucks.
Tamiya tried splines back in the day, and if I remember right it didn't turn out so well.soniccj5 wrote:I understand that the pin is still being used to drive the hex, but once you clamp it to the axle I thought that would add some extra strength. Be even better if they were splined though.
splines stink i had tamiya dif splines strip out on me many times . look at new dif splines on the tamiya mini cooper m05 now (no splines). they are doing this now(no splines) on other cars tooLowgear wrote:Tamiya tried splines back in the day, and if I remember right it didn't turn out so well.soniccj5 wrote:I understand that the pin is still being used to drive the hex, but once you clamp it to the axle I thought that would add some extra strength. Be even better if they were splined though.
some weight on the front could be a good thing for traction... maybe,.. i dont know but i see alot of weight adding items for sale and i would not make that my desiding factor...as i said before the real benefit i see with hex you dont wreck wheels or bearings as much, plus wheel swaps are much faster and easy. ive seen people wreck wheels trying to get bearings out and ive see people wreck bearings the same way..all in all if you need to swap wheels a few dozen times it really puts extra wear on parts even if your a pro at doing it. with hex you dont have to worry about them issues. as far as anything else i dont think hex on a buggy does anything more for you. trucks are cool cause you can swap front and rear tires. im in the same boat as you . i have alot of old style buggy fronts so all my buggies will remain nonhex but if i could turn back time id make all rcs hex so i can swap all truck wheels around and all my 2wd rcs can get the front wheels swaped with out changing out bearings.. you gotta admit if you need to swap out a wheel the hex set up is super easy and fast. ive changed front wheels 3 times at a track. i had to remove bearings each time if i had hex that would have been greatslotcarrod wrote:I built my B4.2 with no hexes! My thoughts are:
First, I have many NEW sets of wheel tire combos premounted for my older B4 and B4.1.
Second, the hexes are much heavier than the older system, I want less rotating mass and less unsprung weight!
Thirdly, if it won't make my car get faster lap times, I don't want it! So why bother?
The bearing placement is bs! Greater stress is placed on an inboard bearing, think of the axle as a leverThe weight of the inner bearings, aluminium hex, steel axle, pin and nut is much greater than bearings, aluminium axle and steel screw of the older system!
SC Trucks, the hex is a great idea but in buggys serve nothing IMO!
Interesting! Do these let you put hex wheels on the front? If so, did you like them? Can you still get them?Coelacanth wrote: ↑Wed Apr 03, 2013 10:02 pm Good point; with in-wheel bearings, sometimes getting the bearings out of the wheels can be a royal pain. And speaking about weight, check out this item I bought which I'll be installing on my OptiMutt project car. I'll call 'em "hexles".I think they're pretty cool.
I have to tell you that this is not the case with the wobble.Coelacanth wrote: ↑Mon Mar 04, 2013 10:25 am Other than standardizing your wheel options, a 12mm hex would provide a more stable mount, as it distributes the pressure from the mounted wheel more evenly. The wheels are thus less likely to wobble, and won't wobble as a result of bearings wearing out. With the bearings-in-wheels mounting method, over time you'd potentially get wear & tear inside the grooves where the bearings fit, the bearing holes on the axle shafts would widen slightly over time, and the bearing inners will also wear over time; all of those things would contribute to a slightly unstable wheel mount.
With hexes on axle shafts, the only thing that would potentially wear out would be the hex depression inside the wheels, and due to it having 6 pressure points, the wheels stay on the hexes very firmly and it's very rare to see broken hex standoffs. Just my 2¢.![]()
Users browsing this forum: juicedcoupe and 4 guests
