but it's still gonna go backwards
The chassis had a small hole in the center of the rear, possibly for a bumper. But after trying several different shock tower designs and shock mounting locations, I decided to countersink the hole and use the extra lowering kit piece I had. It was the easiest way I could come up with to mount the shocks...and it looks cool.losiXXXman wrote:Thsi is a cool car LTOdave. I too like the use of the AE tool to dress it up. Also, ingeneous use of the mcallister RC10 lowering tower on the rear of the car! Is that what the directions for the conversion say to do, or did you come up with it yourself?
I'm not as much of a Kyosho fan as scr8p, but I've always wanted to build and Ultima oval conversion.losiXXXman wrote:Hey dave, don't know your taste for Ultimas, but this same chassis in an Ultima conversion came up the other day on ebay. He had it @ 35BIN or minbid $25. I put it in my watch list to think about, but when I cam back the next day - SOLD.... I hope to see it come back over on the kyosho forum
the motor hangs off to one side because it's a direct drive trans. and if you were oval racing, it's not a big deal. the length of the trans has nothing to do with the belt drive either, that's just how a j-car trans is made. i'm sure he put it on this car because they're both made by hyperdrive, the chassis kit and belt drive. but you could put a hyperdrive belt conversion a 6 gear trans if you wanted to.kink wrote:First of it it looks cool, chunky and retro, which is always good.
But I do not get some things about this car. Why design it with the motor hanging right out to one side. Surely that will affect its handling. Also why belt drive over a pinion meshing with a spur gear? Seems like an over complication and adding extra mass (not just the belt which is irrelevant, but the longer solid metal supports to move the motor further away). Does any rc car use this idea any more?
If you look at R/C across the span of history, just think of all the cool things we'd have missed out on if practicality was in the forefront of every designer's mind.kink wrote:But I do not get some things about this car. Why design it with the motor hanging right out to one side. Surely that will affect its handling. Also why belt drive over a pinion meshing with a spur gear? Seems like an over complication and adding extra mass (not just the belt which is irrelevant, but the longer solid metal supports to move the motor further away). Does any rc car use this idea any more?
Users browsing this forum: Amazon [Bot] and 4 guests
