Modernizing your RC10 - question regarding electronics
General info, Q&A.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: Modernizing your RC10 - question regarding electronics
Post by JK Racing »
scr8p, your right....2.65, gear it the same as you would your B4
mdutcher
Post by mdutcher »
JK Racing wrote:2.25 internals on the stealth....
I'll have to dig up my gearing, but be aware that 3800 is a BEAST, being a 4 pole motor (monster torque, enough for 4X4SC trucks weight 6-8 pounds).
Beast in the sense of just too much power? Or beast in that it could cause some stress to the tranny and internal gearing? My initial thought was to give me the power that I wanted when I felt that I needed it. I don't plan on going full tilt with it all of the time as I like to modulate speed accordingly here and there.
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
mdutcher
Post by mdutcher »
JK Racing wrote:scr8p, your right....2.65, gear it the same as you would your B4
Ok, with that said, what would be a good starting point FDR to shoot for? And correct me if I am wrong, but is this how you calculate the FDR.... (Spur / Pinion)*Internal??
ex. (81 spur / 30 pinion)*2.65 = 7.155
mdutcher
Post by mdutcher »
I also do have the option of swapping out the 3800Kv motor for a not as beastly 4600kv one. I just wanted to start somewhere.
JK Racing
Post by JK Racing »
the 4600 is a 4 pole also...more beastly.
as long as you can control your throttle finger, no issues.
your calculations are correct, I havent looked up my gearing yet, but like I said, match what you would use in the B4.
mdutcher
Post by mdutcher »
JK Racing wrote:the 4600 is a 4 pole also...more beastly.
I thought the lower the KV, the more power. So, it is the higher the KV the more power than? I was a little confused.
I will start with what I have in my B4 than.
Has thanked: 357 times
Been thanked: 470 times
Yup, the KV (killavolt) number is how many RPM it will turn for every volt of input power. A lower "Turn" number ie a 6.5 makes more power than a 22.5 because of less resistance-
RC104ever
Post by RC104ever »
Keep in mind that we are talking about two different ways of measuring power:
kv - the HIGHER the KV, the faster it will turn, but you will have less torque than a lower kv motor (all else being equal)
Turns - the LOWER the turn number, (ie 6.5 vs 10.5), the faster it will turn but it will also have a lower torque number (all else being equal)
So in your initial example, the 4600 kv motor should make your vehicle move faster (more top speed) but it would have less torque than the 3800 kv.
Similarly, a 7.5T motor would be faster than a 13.5T motor but the 13.5T would have more low end torque.
I believe this is why crawlers and heavier vehicles typically use motors with higher Turn ratings or lower kv numbers.
Someone correct me if my above statements are incorrect but that's my understanding.
- Chris
Lots of cars...so many cars
JK Racing
Post by JK Racing »
my understand is almost opposite...
lower KV - lower RPM - lower "watts" or power
maybe?
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
KV*V=~RPM under no load.
A low turn # (e.g. 3.5T) has a higher KV rating than a higher turn # (e.g. 21.5T).
So lower turn motors have faster top end speeds than higher turn motors but lower KV motors have slower top end speeds than higher KV motors. For acceleration it's the opposite.
JK Racing
Post by JK Racing »
finally found what I was looking for...KV/Watts chart...I understand these are Novak motors on the chart, but it should hold true for any motor, as KV goes up, so does watts (or horsepower as I understand it). It may not really be a direct link to torque, but it is as close as I can come to explain my understanding.
mdutcher
Post by mdutcher »
JK Racing wrote:finally found what I was looking for...KV/Watts chart...I understand these are Novak motors on the chart, but it should hold true for any motor, as KV goes up, so does watts (or horsepower as I understand it). It may not really be a direct link to torque, but it is as close as I can come to explain my understanding.
I think that you guys are all saying the same thing. Regardless, it would seem that the higher the Kv, the faster the motor is, when talking about top end speed - this is where I was slightly misguided prior to my post a few days ago. I do appreciate the clarification though.
kaiser
Post by kaiser »
back to the question at hand, power/gearing.
you want to run a 10.5(4200kv) motor (i wouldn't use castle, but thats your call).
using novaks final drive chart http://v2.teamnovak.com/kb/knowledgebase.php?act=art&article_id=29
you want to be at a final drive of 8. using a 81 tooth spur you'll need a 22 tooth pinion.
keep in mind that this is a starting point, you can go up or down as needed just monitot temps.
you don't want a 540 sized bl motor to hit the 170 range.
fredswain
Post by fredswain »
I've got a 4000kv 8.5T motor and I personally think it is way too much power. I'm probably going to go down to a 13.5.
kaiser
Post by kaiser »
fred is that a hobbywing motor? most 8.5's are around 5000kv.
i find 10.5 the perfect mod motor for 2wd. i tried a novak 8.5 (5000kv) and it was crazy, but the 10.5 seems just right.
