Pinky project...
REMJ666
Re: Pinky project...
Post by REMJ666 »
A little more progress...New 5 degree carriers and inline steering arms with aluminum axles , New worlds rear shock tower and throwing some working stuff into the buggy...Yes the servo and reciever are old but they work...They will do for now...
Russ Winn
Has thanked: 49 times
Been thanked: 80 times
Post by Russ Winn »
Looking good so far. (Nice score on the bell crank, BTW)...Be sure to get a good Kimbrough servo saver. Servo gears are cheap, but a pain to keep replacing.
The older I get, the faster I was.
https://www.youtube.com/watch?v=pyGKBTUJ-L0
REMJ666
Post by REMJ666 »
Did you get those RPM arms new or did you already have them ???? Was on the website and only saw the short arms...Thanks for the replies Russ...
REMJ666
Post by REMJ666 »
More stuff...I like stuff :twisted:
Russ Winn
Post by Russ Winn »
REMJ666 wrote:Did you get those RPM arms new or did you already have them ???? Was on the website and only saw the short arms...Thanks for the replies Russ...
I got them on ebay, new in the pack.....cheap, too!
REMJ666
Post by REMJ666 »
That is my next problem to solve...Front A arms and Rear A arms :lol: The ones you got are the wide ones correct ????
Russ Winn
Post by Russ Winn »
They're a little wider than stock, and not swept back as much. You need to run different ball links on the shock bottoms than the original RC10 type. I'm running stock arms in the rear.
REMJ666
Post by REMJ666 »
I really need a set of those arms :lol: This will be the motor of choice for now...Venom Fireball modified 21D...Why all the vintage stuff you ask ???? Because when i went back to my lhs there wasn't anyone there that could tell me what class types they are running for oval...They may not even have a bomber class so i will still build this car for oval and when i take it there to show them i will do my best to convince them that they should...Good thing is that i know some of the oval racers and i think that they will like the idea also...Rebuild this badboy give it a good clean , relube or replace the bearings , get some new brushes and it will be good as new....Magnets are still strong and the comm is not worn at all so there is still alot of life in this motor...
Russ Winn
Post by Russ Winn »
The bomber class here runs 13.5 brushless. I have a venom 15 turn in my TC4, and it'll really come to life with a Lipo in it. They're less than 20 bucks at Tower.
REMJ666
Post by REMJ666 »
I am trying to WOW them with the vintage stuff...
Russ Winn
Post by Russ Winn »
REMJ666 wrote:I am trying to WOW them with the vintage stuff...
I see your point, but I figured in this day and time, ANYTHING brushed was considered vintage. :lol:
REMJ666
Post by REMJ666 »
With the open endbell i can always slip in a hotter arm :twisted: SHHHHH !!!! Don't tell..
Russ Winn
Post by Russ Winn »
How's pinky been coming along lately?
REMJ666
Post by REMJ666 »
Glad you asked...Just finished the stealth rebuild and will post pics shortly...
REMJ666
Post by REMJ666 »
Tranny is rebuilt and back in the car...Everything in the trans was in perfect condition so i cleaned all the parts soaked the bearings overnight in motor clean then reoiled them...Went to everyones most hated place HOBBYTOWN and got a B4 top shaft , slipper pad , slipper spring , vented v2 slipper hub and JConcepts silent speed 48p 84t spur gear...WOOHOO that took forever :lol: If the a arms would ever get here it would look like a rolling chassis...
Users browsing this forum: No User AvatarGoogle Adsense [Bot], No User AvatarTbot [Bot] and 15 guests
