Schumacher Cat 98 questions (rebuild)
dj_kilroy
Re: Schumacher Cat 98 questions (rebuild)
Post by dj_kilroy »
Here's some pics after more cleaning and rebuilding the shocks.
I scored some nice Lunsford turnbuckles which were meant for a Losi xxx4, from a local hobby shop.
These turnbuckles are exactly the right length for this series of cars.
Now I'm just waiting for the new shell, undertray and bearings to arrive.
And another question, are there any alloy hubs with bigger bearings that will fit this car?
Has thanked: 239 times
Been thanked: 337 times
Wow, what a crazy car! This is the first time I've noticed one of these- :oops:
dj_kilroy
Post by dj_kilroy »
Charlie don't surf wrote:Wow, what a crazy car! This is the first time I've noticed one of these- :oops:
Yeah, probably not too common in the State's..
I can't wait to get it running again and see if it can keep up to the modern stuff on the track.
CAT3K
Post by CAT3K »
dj_kilroy wrote: And another question, are there any alloy hubs with bigger bearings that will fit this car?
Not sure about the rears, but the front C hubs look identical to the CAT3000, and you can get those in purple alloy. I don't have the 98 manual to hand so i can't check the part numbers.
Paul.
dj_kilroy
Post by dj_kilroy »
Paul.
Yeah, I'm pretty sure the front hubs are identical to the cat 3000 and it looks like the rears have bigger bearings and may fit.
Do you know if there were any alloy hubs, option or aftermarket?
Thanks
Kilroy
RickRick
Post by RickRick »
good news on the sst parts swap i've got a huge box of sst stuff, and i'm sure there's some purple bits in there, i'll get them stuck on my cats!
dj_kilroy
Post by dj_kilroy »
RickRick wrote:good news on the sst parts swap i've got a huge box of sst stuff, and i'm sure there's some purple bits in there, i'll get them stuck on my cats!
If you have any left over, please let me know.. :wink:
Cheers
Kilroy
dj_kilroy
Post by dj_kilroy »
It's been a long time coming, but here are the pics of the fully rebuilt car.
These shots were taken just before the first track outing and I ran out of time to get shots with the body and new wheels on.
The next pics were taken after racing on the weekend, so the car isn't as clean and nice as it was when finished.
I was pretty happy with the cars performance and it was blindingly fast with the Reedy 7.5. I had a bit of a problem with the ESC overheating due to running 20% drag brake, but this will hopefully be resolved with more weight in the front, less drag brake and cooling holes in the shell. I'm hoping more weight up front will make it turn in better without the need for running so much drag brake.
Sorry about the bad mobile phone pics
crusaderlyf
Post by crusaderlyf »
good car,I have a cat98 all upgraded,I called it cat98 works,I love it
dj_kilroy
Post by dj_kilroy »
That looks really cool with the purple turnbuckles and trans housings.. I wish mine had those.
Are you planning to run and race it?
Cheers
David
Typpo
Post by Typpo »
Both are nice. Are those Ballistic Buggy wheels for Schumacher 14mm hex?
Also, trying to rebuild a CAT '98. Does anyone have a scan of the CAT '98 manual?
dj_kilroy
Post by dj_kilroy »
Typpo wrote:Both are nice. Are those Ballistic Buggy wheels for Schumacher 14mm hex?
Yes, they are Ballistic wheels, I found them on Ebay.
As for a manual, I don't think I've ever seen one. There are copy's of the exploded diagram online somewhere, which is good for part numbers.
These cars are really very simple to build and maintain, with the diffs being the only part that needs a little care. There are "how to build" Shumacher diffs on "u-tube" which will apply to the Cat 98. I hope that will help.
Cheers
David
Typpo
Post by Typpo »
Hello David,
Thank you for your help. The CAT '98 exploded diagram, along with the 2000, 2000 EC, and 3000 manuals are indeed available on the web. I was looking for the CAT '98 manual because each manual lists slightly different information (e.g. currently available parts at the time).
Wheels:
Beyond Ballistic Buggy wheels, have you tried the Durango 14mm hex? Also, did you consider using a 12mm hex to fit those axles?
dj_kilroy
Post by dj_kilroy »
Typpo wrote:Hello David,
Wheels:
Yeah, I though about getting the Durango wheels but didn't want to commit to them until I knew that the offset was the same. I did consider trying to fit newer axles and 12mm hexs, but found the Ballistic wheels and went with those.. I think they look pretty cool.
Cheers
David
Bormac
Has thanked: 21 times
Been thanked: 11 times
Post by Bormac »
I really admire your desire to make this car work out on the race track. That Cat2000 shell is my favourite. I used to have one of this particular mold a few years back and I always wondered what exact version it was.
-Jason.
Still known as- bormac
Return to “Schumacher Forum”
