Schumacher Cat 98 questions (rebuild)
Hi all,
I'm just about to rebuild my Schumacher Cat 98 and was wondering if the shell and undertray from the cat 2000 series will fit.
I'll post pics of my car during the build and hopefully get the new shell and undertray to finish the job.
I've raced the car in the past and will put it back on the track after the rebuild. I'm pretty lucky that I have a good stash of new
parts and it should run like brand new again.
I'm also wondering if anyone else has experience with this series of cars and is still running them.
Cheers
Kilroy
Cheers
Kilroy
Re: Schumacher Cat 98 questions (rebuild)
Hi
The cat ec shell is the same as the 98, the undertray is the same across the 2000's so they would all fit..
would be great to see this rebuild post some pics up
Mick
Mick
Thanks for that, I just bought a 2000 ec shell and undertray after studying pics of both cars.moozo wrote:Hi
would be great to see this rebuild post some pics up![]()
Mick
I can't wait to get it back on to the track.
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
"I look to enjoy"???? Come on Jason, you'll give the appearance that down here in Australia, English is not our first language.....J.M. wrote:I look to enjoy your build thread Dave. We love pics![]()
I mean, corr struth cobber.... fair crack o'the whip, bloke...
You guys crack me up!
Here's some pics of the build so far.
As you can see from the pics, I've given the car a good clean, replaced the belts, re lubed the diffs and bearings and started work
on adapting the chassis for lipos with parts donated from a b44.
All that's left to do is rebuild the shocks, and clean out the wheel bearings and maybe fit new front hubs. The old hubs are very sloppy and make it impossible to set the right camber.
There are a couple of trick aftermarket parts from Shumacher included on this car, which I scored from Alex (Incredible serious) a few years ago.
3 degree rear suspension arm mounts, 5 degree caster blocks (I think) and a one way clutch to the front wheels, which can be locked out for constant 4 wheel drive. (The standard one can't be locked)
And another question.... Doe's anyone know if CAT SX drive shafts will fit the CAT 98 (same length and same size axel)
I'd like to change just so I can run newer wheels and also because I don't like the tapered press on hex arrangement.. (it is crap!)
The next thing is to score some purple turnbuckles and have a new shell and undertray on the way.
It should look good on the track!
Cheers
Kilroy
Cheers
Kilroy
Original Shell and undertray.
You can see why I'm getting new ones..hehe
I'm guessing too much yellow.....dj_kilroy wrote:You can see why I'm getting new ones..hehe
And not enough purple.Incredible_Serious wrote:I'm guessing too much yellow.....dj_kilroy wrote:You can see why I'm getting new ones..hehe
Speaking of purple... Do you have the purple trans housings and want to sell them?
Nope. Have some parts left, but from memory they're mostly standard parts, and/or used parts.dj_kilroy wrote:Speaking of purple... Do you have the purple trans housings and want to sell them?![]()
Thats OK, I have a cunning plan!Incredible_Serious wrote:Nope. Have some parts left, but from memory they're mostly standard parts, and/or used parts.dj_kilroy wrote:Speaking of purple... Do you have the purple trans housings and want to sell them?![]()
- Bormac
Come on Alex, sure you have all those sweet purple Schuey bits stashed away with all your other treasures
Again, nope.J.M. wrote:Come on Alex, sure you have all those sweet purple Schuey bits stashed away with all your other treasures
(Like!)Incredible_Serious wrote:Again, nope.J.M. wrote:Come on Alex, sure you have all those sweet purple Schuey bits stashed away with all your other treasures
Don't you wish RC 10 talk had a like button...
Anyway I think I've found a source for those purple parts... The Axis and SST touring cars have the same parts and are on ebay all the time.
Sheesh I just gave away my secret!
- 27 Replies
- 3557 Views
Last post by Asso_man!
- 4087 Views
Last post by Eau Rouge
- 2290 Views
Last post by Typpo
- 20 Replies
- 5203 Views
Last post by QuackingPlums
- 1350 Views
Last post by minichamps11
- 1189 Views
Last post by mtbkym01
- 1399 Views
Last post by isobarik
- 1860 Views
Last post by CNA75
