Shelf queens and oils
- LurkingCAT
- Has thanked: 202 times
- Been thanked: 271 times
Re: Shelf queens and oils
Prefer no oil and from time to time I have shocks I don't get rebuild parts for or simply won't use new rebuild parts on. As a former watchmaker I would recommend silicone grease. Used it on all sorts of o-rings in watches. It's keeping gaskets (and shocks) smooth for years. My personal preference is the Moebius 8513. For a nice and even layer of grease I have had some success applying the silicone grease with foam rubber and carefully dabbing the o-rings.
- wait a minute
this is what i use. it works good.newob wrote:good point. green slime work well also.jwscab wrote:I put a few drips of oil in to assemble and make them smooth, but that's all. Definitely not 'dry', but empty.
wait a minute
- Been thanked: 325 times
Just a question: If leaking isn't a concern, what are the benefits of having dry, empty shocks on shelf-queens, if any? Other than saving a little time and money, I guess?
- LurkingCAT
Generally agree to have oil in self queens, my problem is too many grandmas with sligth signs of incontinence...
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
My problem is remembering what oil is in what car. I even made a handy dandy spreadsheet to keep track of all my setups but somehow it never gets updated.
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
Leaking shocks don't sound so bad now.LurkingCAT wrote:Generally agree to have oil in self queens, my problem is too many grandmas with sligth signs of incontinence...
most of mine are empty, without seals fitted, but then they were either leaking or needed a rebuild for whatever reason, so i didn't see the point in putting in new seals, there mainly the same as current cars are using so there's no worry about supply for me, the cars that i might want to run are filled, or i steal a built set from one to service another if it's going to get a run out
- skunk.werkz
Green slime liberally applied to all seals. I don't see any reason to have fluids in a shelf car, just another variable to make a mess if they end up leaking. I used to fill shocks, even rebuilt ones only to leak and have to pull the shocks apart, soak them in soapy water to clean residue and build them dry.
- RABIDFOX50
- Has thanked: 10 times
- Been thanked: 5 times
I just rebuilt two sets of shocks and I used the green slime on the seals and no oil. If I ever run them, I just fill them with the oil I need. No muss no fuss no mess.
- 1160 Views
Last post by winner_evo
- 1522 Views
Last post by scollins
- 1201 Views
Last post by License2iLL
- 2914 Views
Last post by badhoopty
- 905 Views
Last post by BobW
- 2508 Views
Last post by Tadracket
- 1211 Views
Last post by slim_chance
- 30 Replies
- 3519 Views
Last post by spider
Users browsing this forum: Google Feedfetcher and 4 guests
