THE BLACK THING (T2 hybrid...) NEED HELP WITH BODY!!!!
Tadracket
Post by Tadracket »
B3 appears to be too short and narrow in the nose. The body I have is already cut so my figures are off a Tad. BTW, I borrowed your photo.
Image[/img]
He's an idiot. Comes from upbringing. His parents are probably idiots too.
AYKBOBCAT
Post by AYKBOBCAT »
I see.... What is the total lenght of the body? I can't figure it out because the lenght between the two vertical lines is not there. On the other hand you added some thta I forgot to put :)
It looks like it would fit but that the nose would be too narrow as you say...
Hopefully someone will do the same as you did with another shell so I can find one Thanks a lot!
By the way, to whoever is using the sand viper or the other one alike that I forget the name.. I would love to get measures for that one. I like that shell.
mrlexan
Post by mrlexan »
Ferretti put a sand viper on one of his Ultimas. Ask him.
Tadracket
Post by Tadracket »
AYKBOBCAT wrote:I see.... What is the total lenght of the body?
Total is 35.56 cm. I should have put it on the other side of your original measurement. Sorry 'bout that :oops: .
Bugle
Post by Bugle »
I tried the remains of a B3 body on a T2 yeah just a bit short and narrow at the front
AYKBOBCAT
Post by AYKBOBCAT »
Thanks for that I appreciate it... So It isvery much to short then. was the nose cut shorter on that body of is it complete?
Thanks again
Bugle
Post by Bugle »
The nose is cut at the normal place but jammed up against the shock tower so it'd sit just a little further forward than the shock tower on yours but there'd be a big gap either side of it. Maybe you could bend up a bit of lexan and glue it onto the front of the body to make it look right.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
I cut up my desert gator for a narrow look on my ultima, so not many dimensions to share.
But the ones i got are not encouraging:
- length from back of cockpit ( against shockstay) to nose tip 26 cm, or 4 cm short of what you need.
It might be just a bit longer but not much: I'm quite sure I didn't remove much in this area.
- The nose is narrowing down from 6cm at 8cm from the nose tip to 4 cm at the the nose tip
The sand viper will be almost the same lengthwise but has a narrower nose even.
I think a losi, JR X2 or more recent will fit better or you could move away from buggy to (stadium) truck, classic, ...
Before I forget: I think this a super-cool project.
Don't dare giving up on it yet.
AYKBOBCAT
Post by AYKBOBCAT »
Thanks for the info I realy appreciate it. Don't worry I can be patient for this kind of stuff. I have other projects to keep me busy when one get stuck as it is the case for this one. I think I may have to take it to a hobby shop one day and try to see what could fit eventually... All I need really is a relatively LONG nose buggy shell :D
Mr. ED
Post by Mr. ED »
It would be most unique if you made you're own:
Use the tub to cast a base and complete the mould with a home designed cockpit.
Allways wanted to try a skull design myself :twisted:
AYKBOBCAT
Post by AYKBOBCAT »
Yeah it's a good idea but I am not very good at this kind of thing... :oops:
carloco8
Has thanked: 64 times
Been thanked: 225 times
Re: THE BLACK THING (T2 hybrid...) NEED HELP WITH BODY!!!!
Post by carloco8 »
Bringing back a not so forgotten thread I hope? I started working on a similar project and was wondering if anything might fit a T2 chassis buggy? I realized that with the nose plate in the shortest configuration, the car still pretty much has a truck wheelbase. I only have Associated buggies and tried their bodies from the original rc10 styles to a B4 with no luck. I'm pretty sure the losi bodies have a nose that is too narrow and haven't yet looked at any tamiya bodies. Any advice guys? Thanks!
AYKBOBCAT
Post by AYKBOBCAT »
Well well
My in on the shelf since quite a while. I did not abandon it but I started building another one. I still don't have a body for it. The Associated ones are definitely too short. there must be a Tamiya one or from another brand that would fit.
Didn't Schumacher made long wheel base buggies at one point? Waybe a 4wd buggy body would work?
Mr. ED
Post by Mr. ED »
You may wanna take a look at the Traxxas Bandit.
Don't know if it fits, but should be cheap and easy to find.
Has thanked: 33 times
Been thanked: 1193 times
i still really like that car. one day, i think i'll partially build one. :lol:
Return to “RC10 Truck Forum”
