Composite Craft LX-T
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: EBay score
CC is killing me...if they re-do this chassis, it will be ANOTHER new chassis I will order from them. The CC/Worlds chassis is on the hit list right now, just got done talking to the wife about it. Now I need to talk to her about the SE/LXT chassis
- bearrickster
Re: EBay score
Well I was building a Composite Crraft car about a year ago, when as you know I got talking to one of the guys at Composite craft. He asked if he could use my NIP chassis to redraw it up in their new system. I was starting to think I wasnt going to ever get it back and it showed up. well the deal was I would get one of the new ones for my trouble. so here it is, the new one is Carbon Fiber not just plane carbon. So here it is I think the new one is much cooler.
The only issue I see is they drilled the sterring post holes to big, but thats my fault I had mine drilled out for the RPM sterring I am useing on mine. it mounts with 8/32 not 440 screws.
- JK Racing
Re: EBay score / Composite Craft LX-T
RICK...your back
good lookin' chassis right there. damn...I just heard my wallet wimper.
- bearrickster
thanks JK its good to be back. I am looking foward to building my LX-T on that carbon chassisJK Racing wrote:RICK...your back
- bearrickster
Well I made a little progress on the LX-t, I was moveing right along and hit a road block. I was digging out all of my nip parts for a new Retrofit trans and started putting it together when it hit me I have to grind a slot for the trans to fit. so I stuck a LRM case on their to see how it looked. so should I cut the relief in this beautiful chassis for the retro fit or just use a LRM?
By the way I used nip RPM steering blocks and front arms. Lunsford TT Turnbuckles, I cut a custom Blue Battery pad to go with my custom Blue motor plate I have blue shocks to go on it also. the RPM sticker will be comming off I just stuck it their to keep the finger prints off the new pad.
- highwayracer
- Been thanked: 6 times
hey Rick,
I ran into the same problem when I mounted my MIP trans on the jrxt. It "should" fit, but the alignment wasn't right...and it threw off the motor mount. I wound up making a spacer that raised the bulkhead and rear pivot block. There was a hole to allow the trans to sit lower.
Since you have the top plate, you just need to add thin spacers on chassis posts.
Regards,
Roger
Regards,
Roger
- bearrickster
thats a good Idea, I think I may just cut the chassis though as I do plan on running this car if I can make it to the Vornats again. we will see
- bearrickster
Re: Composite Craft LX-T
I am looking for a set of Losi thredded shocks and I think I will have them done like the motor plate. I am also looking for a body something Chevy anything but stock
- JK Racing
Rick, if you are just shelfing this (cause I dont know how good the shocks are or arent), I think the Speed T or Speed NT or maybe the Strike came with threaded blue shocks. I may be wrong though.
- slapshot1979
My losi strike has threaded blue shocks.
- bearrickster
no I plan on racing it if I can make it to the Vonats again. I am going to work on a undertray for it. I had 2 nip but sold both on car I sold now I wish I dould have kept one.
Thanks for the info I will look those up.
- bearrickster
- JK Racing
I'll keep my eye open, but it was sheer luck on the one I got.
- bearrickster
Well I havent worked on this one in a while, have made a little progress. but I need to get off my but and finish it, its never taken me this long to build a truck. I bought nip losi xXx threaded shocks Mip gold shafts new cart. built up the shocks. I really need to start the hunt for a body. and start building the new xx retro fit trans thats going in it. I want this one to be my runner at the next Vintage Nats I go to.
- 3205 Views
Last post by Harrylarry
- 1213 Views
Last post by ericsp2
- 771 Views
- 23 Replies
- 2239 Views
Last post by bearrickster
- 1204 Views
Last post by Lonestar
- 3137 Views
Last post by GJW
- 2802 Views
Last post by carloco8
- 810 Views
Last post by tomolupus
