got this yesterday
Re: got this yesterday
the 6 gear trans doesn't have a slipper.
bigmd
Post by bigmd »
it has a spur with balls in it sandwiched between 2 plates and an adjusting nut.
victor_cathedral
Post by victor_cathedral »
that is the differential gear, the top shaft is actually two shafts, the back side of the "slipper" is the outer shaft, which connects the right side outdrive, and the right half of the transmission. the outer side of the "slipper" is the inside shaft, which connects the left outdrive, and the left half of the transmission. the tension on the spring adjusts the amount of force needed to spin one half of the transmission at a different rate opposed to the other. so yea,.. thats ur diff :P ( the balls should be lubricated with associated diff grease )
bigmd
Post by bigmd »
its missing a few balls.anything at tower i can use?
victor_cathedral
that i do not know, there is probably a topic somewhere on this forum about it, problem is finding it :mrgreen:
bigmd
Post by bigmd »
any idea on how to get stuck bearings on front axle?also are the RPM front arms the same length as the associated wide arms?
WillyThickfoot
Been thanked: 9 times
Post by WillyThickfoot »
I got Andys black arms on mine and they look great. Lots of them on ebay too!
muck
Post by muck »
your diff balls http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2760&P=7
your manual
http://www.theshreves.com/rc_stuff/manuals/associated/graphite_manual.pdf
Andys arms are the same length as the stock white ones. I think the RPM ones are too but not 100% on that. I just picked up a graphite last week with both the white and andys..
treehugger
Post by treehugger »
Thats a sweet 10 if your going to restore it (fingers crossed) lmk what you need i have a bunch of whites to bring it back to life pm me if you need some parts (arms balls bat cup bumper and period correct gear cover i think i have all you need :wink: ) i think i have black idler gears to .plus a few 6 gear Donner trans so lot of spares i have restored two of these buggys and find them forgiving for the first timer as the cf dont scratch like the anno :shock: 8)
Paul
bigmd
Post by bigmd »
Paul,thanks.Im not sure which way i want to go on this.I tore the whole thing down and am figuring what i need.The front inner wheel bearings are stuck on the axle so i need to figure out how to get them off. I guess i am going to need the gear cover too.i ordered a battery cup but in black.do yo have any suspension pivot ball?i have a few mismatched ones.the factory tie-rods are the same as these?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2540&P=M
take the axle out of the knuckle and soak it in some penetrating fluid. if that doesn't loosen it up, then put the nut back on the axle so it's flush with the tip. set the hexed part of the axle inside a socket or whatever you can find that the axle will pass through but the bearing will sit on top. then gently tap the axle nut to break it loose.
THE H.P FREAK
Post by THE H.P FREAK »
HI!... Just use a set of side cutters and put the flat side of the cutter away from the bearing. Just squeeze and the bearing will pop off. I do this all the time and works perfectly, with no damage. It also works good for getting stubborn pinions off the motor shaft.
bigmd
Post by bigmd »
hey guys since i was originally after my buddys stock clodbuster i may be will to trade this car for a stock clod.let me know if anyone interested.then someone can give the proper restore.
bigmd
Post by bigmd »
got it all torn down.upon inspection i found cracked rear hub carrier,bent tierods and a bent swingshaft.anyone have link for suspension balls?
i'll give you what you paid for it.......
