TC's RC10 Project X (now with build list)
- Toasted Coastie
Re: TC's RC10 Project X
My wife is going to be bent when I get home, there are 11 packages waiting on my doorstep.....
- Toasted Coastie
Pictures when I get home from work tonight but, I dyed parts and started assembling last night. One question though:
What is the difference in the 6 gear motor mount plate and the stealth motor mount plate?
I'm going to put the six gear on there for now, dye the parts tonight. The motor I got for this build is 4900kv with a 2cell LiPo. You think this is too much until I find a stealth plate for my new tranny?
Thanks everyone
Thanks everyone
- losiXXXman
- Been thanked: 5 times
I was under the impression that the original motor plate also fit on a stealth...
- Toasted Coastie
OK. I will look at it. However, the stealth unit itself looks like the bottom holes will not line up where the 6 gear mounted on the chassis plate...losiXXXman wrote:I was under the impression that the original motor plate also fit on a stealth...
I'll take pics tonight....
- Has thanked: 36 times
- Been thanked: 1318 times
3 of the 4 holes will line up, but you have to drill and tap the fourth.losiXXXman wrote:I was under the impression that the original motor plate also fit on a stealth...
probably should've drilled the new trans holes in the tub before having it powder coated, too.
- Toasted Coastie
Yeah. I'll see what I can do. Another question before I head home, with stealth guts fit in a 6 gear tranny case?scr8p wrote:3 of the 4 holes will, but you have to drill and tap the fourth.losiXXXman wrote:I was under the impression that the original motor plate also fit on a stealth...
a stealth and a 6 gear are 2 totally different animals. nothing internal is interchangeable
- Toasted Coastie
Ok, sounds good. I will re-evaluate over a couple beers tonight.....scr8p wrote:a stealth and a 6 gear are 2 totally different animals. nothing internal is interchangeable
- Toasted Coastie
had a cigar. had a couple 10 beers and a second cigar, and decided the stealth is going in anyway. Going to New Era in the morning for a discussion.
I've been slow to post pics because, well, I'm lit and on my netbook in the garage contemplating....
- Toasted Coastie
Car is coming along, but I have noticed some things I have done wrong so far:
Ordered the wrong parts
rushing
I ordered the wrong front tower from Fibre-Lyte and have ordered the right one
ordered towers from eBay and now don't need them
waiting on screw kit and other parts
Looks like I will have plenty of parts for a second car though.....
Now some positives:
This car is BLACK. The carbon fiber and black dyed parts look fantastic. The Klein arms have a deep onyx like appearance to them. The JConcept wheels look sick as well.
Dying parts was a hit or miss at first for me. However, I found that keeping the hot plate on medium but not boilling, letting the parts sit for 5 minutes, dipping them in cool water for 2 minutes then repeating really got the parts the dark look I was looking for. I repeated the process 4 time for each part.
I've been slow to post pix because my main computer at home has crapped out.
rushing
Now some positives:
did you get the klein arms for the front and back? if you try to use them on the front with a buggy nose plate, the front end is gonna be VERY wide compared to the back.
- vintage AE
- Has thanked: 29 times
- Been thanked: 36 times
scr8p, didn't you use a axle spacer? in the REAR so you could move the shocks to the last hole on the arms? I would recommend that.
i used kranzels wheel spacers (on top of the b4 wheel spacers) mainly to have more clearance at the outer shock mount so the wheel wouldn't hit the arm during race conditions. but it still wasn't enough to be able to use the outer shock mount hole without the tire hitting the shock. i could've spaced the rear out a little more, but i was already as wide as i could go on the front, and didn't want the rear wider than the front.
- Toasted Coastie
Yeah. I have changed my mind again after looking at it put together last night. I had to use spacers to keep the travel of the arms to a minimum. I have ordered the different nose plate and will continue on as originally planned.scr8p wrote:did you get the klein arms for the front and back? if you try to use them on the front with a buggy nose plate, the front end is gonna be VERY wide compared to the back.
I' m kind of a learn by error person.....
- Toasted Coastie
Received the GT nose today. Waiting on screw kit.. Have pictures, but picture computer stb.... Will work on that when I get home from camping trip this weekend....
- 23 Replies
- 4559 Views
Last post by Nige55
- 2191 Views
- 1500 Views
Last post by Grumbles
- 1668 Views
Last post by sandkil
- 38 Replies
- 4497 Views
Last post by JOESGARAGE
- 24 Replies
- 2395 Views
Last post by rctenracer
- 37 Replies
- 6680 Views
Last post by Dadio
- 36 Replies
- 8728 Views
Last post by blubblood
Users browsing this forum: howsyouraspen and 4 guests
