OK thgis is great! I should be able to figure it out from there. Thanks!isobarik wrote:AYKBOBCAT wrote:Ok to the risk of looking stupid I'm asking this again to make sure I get it properly before sepending 50$ on a set
I understand that the UM510 has 62.5mm bones from pin to pin. Then there is the axle that is 2mm longer than stock with the 3 grooves. but how long is that axle? I want to find out if it fits in the front hub of the proradiant.
Thanks for the help ans sorry for insisting
Oh and I forgot to ask... What part of the eaxle is longer? I mean, is the cross pit at the same position and there is more thread or is the thread the same lenght and the pin is farther away from the cvd articulation?
Look at it like this 62,5 bone with stock axles same lenght as old ultima (W5061) and the 3 groves ar 2 mm longer. Lenght on the axle is as you guessed the thread is same but the distance from the drive pin to the end where the bearing comes to an halt is longer.
The distance on my Um510 ( 3 grove axle ) is 15 from the pin to the end where the bearing stops. from the pin to the other way is 2 mm where there is no more shiny axle and then basicly the thread begins.
mvh Isobarik
Someone foud compatible CVD (front) for the proRadiant?
Re: Someone foud compatible CVD (front) for the proRadiant?
- Been thanked: 10 times
Any more questions let me know.
mvh isobarik
mvh isobarik
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
I just had a look at the manual of the ZX-5 (original editon and the axle closest to 69mm is LA 231 =68mm from center of the crosspin to the center of the crosspin at the cvd site. I belive these come swith the stock axle= shortest distance from bearing face to the crosspin for the hex
yes they come with the stock axle witch is the shortest one.Mr. ED wrote:I just had a look at the manual of the ZX-5 (original editon and the axle closest to 69mm is LA 231 =68mm from center of the crosspin to the center of the crosspin at the cvd site. I belive these come swith the stock axle= shortest distance from bearing face to the crosspin for the hex
they are also avaliable from 3 racing if i dont remember wtong the 3racing type is non rebuildable but they are very cheap.
mvh Isobarik
- Mr. ED
Any idea who sells 3racing and/or kyosho online? (preferable outside of e-bay)
edit: oh, and what lengthe is the axle part on the 68mm CVD's? (between the inner face and crosspin)
Mr. ED wrote:Any idea who sells 3racing and/or kyosho online? (preferable outside of e-bay)
Stock axles are 13 mm i think i can take an measurment later.
Dont know any besides ebay that cary the 3racing axles.
mvh isobarik
- Mr. ED
ok, so who does them on ebay? and thanks for the measure
ju
mvh Isobarik
Just type "kyosho lazer" in the ebay search and you will find them.Mr. ED wrote:ok, so who does them on ebay? and thanks for the measure
mvh Isobarik
- 541 Views
- 1338 Views
Last post by rccars4sal
- 1053 Views
Last post by RC104ever
- 25 Replies
- 4927 Views
Last post by JK Racing
- 1335 Views
Last post by Sparky27
- 824 Views
Last post by ca-rj
- 997 Views
Last post by Asso_man!
- 2248 Views
Last post by RCveteran
