B4.5
Forum rules
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 470 times
Re: B4.5
Are you allowed to mod those tires in any way per the rules? (Someone mentioned so mods BK was doing to the rears to cure some of the side bite issues the rearbar drag tires have) And, hey- you make an new rack with different ackerman settings there or am I seeing things?
Re: B4.5
No we can't modify the tires in any way. I tried modding the rims to widen the tires, and flatten them out. However my CA must have been a little too old as they blew off the rims within a few laps. I picked up some fresh CA, reglued, but ran out of time before the track closed. I will be tring them on friday. And no, you are not seeing things
. I have two different styles that I have been running. This (the first one) is pretty good so far. It also still has the original holes too. -Jeff
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: B4.5
isnt the BK "mod" to the tires to wear them down (lowering pin height), makes them "walk" less?
Re: B4.5
I believe that there was a trimming of the sidebar section to put additional pressure on one particular side bar too-JK Racing wrote:isnt the BK "mod" to the tires to wear them down (lowering pin height), makes them "walk" less?
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: B4.5
Post #214 of this thread gets into it..?
http://www.rctech.net/forum/electric-off-road/490323-aka-1-10-tire-thread-15.html
- JK Racing
Re: B4.5
bringing this one back up top,
I took my T4 chassis in to the workshop area at work, they are going to use the bandsaw and chop it down for me.
- mdutcher
Re: B4.5
This is a very cool thread. I wished that I had the expertise and know how to machine stuff like you guys do.
Let me ask you guys.... what is your background? Engineers? I am a finance guy and can only calculate how much these projects cost.
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
- longboardnj
Re: B4.5
nice build .. sorry i didnt read all 9 pages. im thinking of doing a t4 chassis b4.. does the b4 worlds body fit ? is that the body in the pics? can you use stock body mounts?
- JK Racing
Re: B4.5
when I get to it, I am planning on an RB6 body. I think the +8 worlds body should be okay, I think the T4 chassis is +10 over the standard chassis. I dont want to use the AE based bodies due to the narrow chassis I am working with.
Re: B4.5
It's +12mm (not that big of a difference)JK Racing wrote:when I get to it, I am planning on an RB6 body. I think the +8 worlds body should be okay, I think the T4 chassis is +10 over the standard chassis. I dont want to use the AE based bodies due to the narrow chassis I am working with.
Re: B4.5
Not yet, they're in process......meanwhile look what AE releasediamogre wrote:Awesome project! Makes me want to find a b4.1 to play with. Did you local track open back up, Reggie?
- JK Racing
Re: B4.5
other than big bores and slightly altered towers, meh....
I will keep working on my +12 project car. Our shop at work had the chassis for almost a month and hadnt touched it
so out will come mr dremel this weekend and I will attack/hack it up!!
- slotcarrod
- Been thanked: 45 times
Re: B4.5
Judging from the manual on the B4.2, the shock towers are the same part number, they may be making a running change only to accommodate the larger bore shocks (no grinding). No forth hole on the rear tower that I can see. The 12 mm hex is new oem, but the most important is the new slipper!
Rod Littau
- longboardnj
Re: B4.5
hope they dont use new spurs .. id be pist if i cant use the b4 t4 sc10 spur gears i have..most important is the new slipper!
